Hello,
I've been using VSO DivXtoDVD to convert things lately and have been very impressed with the speed, quality, and ease of making a movie DVD without a menu. I would now like to try making an episodic TV show DVD, but would like to have a menu for it. If I use DivXtoDVD to convert the videos, is it possible to edit it in another program to create a simple menu?
Please help!
Thanks,
Benhermies
Results 1 to 9 of 9
Thanks for the tip, but I seem to have bad luck with TMPGEnc DVD Author. I've made a whole bunch of DVD's with it, but when I got around to actually watching them they'd die on me. Sometimes in the middle of the video, and sometimes even at the menu itself! Out of the 20 odd DVD's I've made with it, only about 4 are any good.
Any alternate suggestions?
Thanks. -
It's an RCA DVD player, about 4 years old, can't remember the mode, but generally plays everything. I used about 3 different brands of DVD+-R's when I used TMPGEnc DVD Author (Ritek & others). DVD-Lab doesn't give me problems. Can I use that or something else to add a menu?
Yep, the DVD's I make with DivXtoDVD work flawlessly. Not a bad disc yet.
My old method of converting videos was to use Mainconcept MPEG Encoder to convert the files and then compile a DVD with DVD-Lab. Sometimes it worked fine, but quite often the sound would go out of sync. I'm not sure if it was Mainconcept or DVD-Lab that would do that, or maybe even both because sometimes I'd try TMPGEnc/Plus/Express with similar results.
The problem I'd get with TMPGEnc DVD Author, it would just stop... that's it. I'd have to power off and on the DVD player to eject the disc.
I have tried DIKO, AVI2DVD, and The FilmMachine, and most often then not they will crap out on me during the conversion saying some part of the AVI file doesn't meet some standard or something. UGH!
HELP!
VSO Blu-ray to DVD
By Bonie81 in forum Newbie / General discussionsReplies: 0Last Post: 20th Jan 2011, 12:40 -
DivX DVD Disc with Menu
By MI6 in forum Authoring (DVD)Replies: 3Last Post: 6th Jan 2009, 10:07 -
divx on dvd with menu
By Bassmouse in forum Authoring (DVD)Replies: 8Last Post: 9th May 2008, 15:37 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 10:24 -
DivX DVD with menu
By Cico Mico in forum Newbie / General discussionsReplies: 3Last Post: 7th Sep 2007, 03:37
