I have tried to make a VCD out of a AVI file. I started with changing the format to mpg1 with TMPG and this works fine. Then I made a .cue and a .bin file of it with VCDImagerGUI, then I burned it to a CD-RW and this to worked just fine.
The problem is that when I try to play it in my (standalone) DVD player (that should be able to play VCD) it's says "NO DISC FOUND".
What could be the problem?
I really appreciate all answers!
there could be alot of different things causing your problem, like, does your player support cdrw's, need alot more info, what setting did you use in your conversion, what program did you use for the conversion, why did you create a cue bin file, what burning program did you use, etc.
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 23:18 -
Found Two Meteorites
By budwzr in forum Off topicReplies: 11Last Post: 22nd Feb 2012, 10:34 -
I think I have found the best spray!!
By RickTheRed in forum MediaReplies: 113Last Post: 22nd Aug 2011, 01:54 -
Copping Disc - Disc Data Recovery Software.
By Teac23 in forum DVD RippingReplies: 5Last Post: 1st Oct 2010, 21:06 -
Found pulldownbatchFE
By Krelmaneck in forum Newbie / General discussionsReplies: 4Last Post: 25th Sep 2007, 15:17
