I have a problem backing up the movie I transfer it from disjc to hard drive with DVD Fab Decrypter it does that good but then I try to shrink with DVD shrink it gets to around 54% then a box comes up saying virtual memory low I know Ive got lots of memory on my hard drive Ive tried this a few times with the same out come can any give me some help please
One thing you could do, is not post twice in future please.
Also you might try a search as this topic has been discussed
in some depth already.
Mod Offline
Results 1 to 16 of 16
You might check this thread: https://www.videohelp.com/forum/viewtopic.php?t=284666
I cannot use ANYdvd as I used up my trial do you have to use it I tried the new DVD FAB DECRYPTER please Im new to all this can anyone give me step by step how to on backing up Madagascar
Thanks in advance for all the help -
if you used fab i don't see why it wouldn;t work for you.
rip it with fab decrypter, shrink it with shrink and burn with decrypter. on to the next one -
After you rip it to your harddrive run it through VOBBlanker. Run Shrink on that and all should be fine.
drew23977,
I had the same problem you're describing. If running it through VobBlanker doesn't fix the problem (it didn't for me), you can try what eventually worked for me. Here are the details. If you haven't tried it before, CloneDvd has a free 21 day trial. -
Hi, I've been having exactly the same problem as Drew. Ripped it successfully with DVD Fab but then get an error message in DVD Shrink saying that I'm out of memory. This usually happens when I'm around 75% of the way through encoding.
I'm currently running it through VobBlanker (first time user of that program) and have tried to blank what looks like the bad cell in VTS_08_01 - will then try to shrink again & see how I go. I'll post the results later this afternoon.
I've read elsewhere on this board that you just have to run the file through VobBlanker without actually blanking any cells. What would that achieve? Surely you need to correctly identify the cells that are causing the trouble to make that process worthwhile? Anyway, as I said - I'm just learning how to use that program so I don't quite understand it all yet... Any other tips? -
that was a rather recent fix in dvdfabdecryptor that particular movie appearently has something thats "like ARcoSS, but not exactly the same" if you use an updated version of it, though, it can appearently run right through this protection.
Just letting you know that I managed to successfully backup my copy. As I said above, you need to blank out the cell within VTS_08_01 that is causing the problem. After you have done that, hit "Process" (in VobBlanker) and then shrink your output as normal with DVD Shrink. I have tested my copy & it works fine. It's worth noting that the first time I tried using VobBlanker, I hit "Process" without actually blanking any cells. This didn't work for me, as I kept getting the "Out of Memory" error message. As soon as I blanked out just the one cell, it worked perfectly. Thanks to everyone here for their ideas...
I'm having a problem with the <removed>.
I downloaded the .avi file.
You are in breach of the forum rules and are being issued with a formal warning.
Please reread the rules reguarding the discussion of warez, thanks.
/ Moderator Faustus -
Sorry for that last post!
I have no audio when i burn a 12 minute dvd onto a cd-r.
video looks great. any help would be appreciated.
thanks -
Correct.Originally Posted by whitejremiah
And, for what it is worth, this copy protection scheme (on "Madagascar") has now been confirmed as the first disc to be released with Macrovision "RipGuard" on it. (This has been reported by Forbes, there is an item in the "NEWS" forum here with more details).
Here is a link to the news item:
http://www.forbes.com/personalfinance/philanthropy/2005/11/22/macrovision-dvd-ripping-...markets03.html
[NOTE: You may have to click on a "skip this item" link, before you will see the actual article.]
So, it would seem that Macrovision's much ballyhooed RipGuard has turned out to be nothing more than a variation on the scheme which Sony has been using on most of their new releases since last December (ARccOS). It is interesting that Macrovision claimed it would appear in mid-summer, and it was either "not ready for primte-time" back then, or else none of the distributors were gullible enough to actually pay for the product until this one, in late November.
The much-feared, much-dreaded RipGuard has turned out to be "much ado about nothing..." it would seem.
There are mutliple means of still backing up your legitimately owned copies of this disc. The latest DVDFab Decrypter is one route. DVDDecrypter with a PSL file can handle it. Running the thing through VobBlanker as in intermediary can "blank" the deliberate errors, as well.
-Bruce -
Check the newest version of Anydvd just released today:
"AnyDVD History
5.6.1.1, 2005 11 27
- New: Added detection and removal of a new type of protection
"MacroVision RipGuard" as found on "Madagascar WideScreen" R1 (US)
or "Vet Hard" R2 (Netherlands) to the option to remove
"Protection based on unreadable Sectors"
Note: RipGuard could be copied together with elby CloneDVD2 since
AnyDVD version 5.4.1.1, but this new version supports drag and drop
of all files from DVD to harddisk as well!
- New: Added support for a new version of the Sony Arccos protection
as found on "Seinfeld Season 6 Disc 3" R2 (German) to the option to
remove "Protection based on unreadable Sectors"
- New: Information Window now shows MacroVision RipGuard, if it was
detected.
- New: Information Window now displays, if "Error zones between files"
have been removed, like on "Resident Evil - Apocalypse" R1 (US)"
This program is well worth the money if you backup a lot of your movies!
I used Anydvd 5.5.5.1 and DVD Fab Decrypter 2.9.5.2 and had no problems. I also tried just processing all files thru VOBblanker and then using DVDShrink and that also worked, it removed the "unreferenced material" that seems to be a part of this new protection. It appears to be in VTS_08_01 cell 2 that the Madagascar protection is in. -
Originally Posted by funny guy
Well, today eh.... huh.........
DVDFab Decrypter ripped it fine for me like... over a week ago... and even before they released a new version to rip it and allow it to be backed up, i still did it without ever haveing AnyDVD on my pc... ever 8)
Should have checked the new version of DVDFab Decrypter about 3 version's ago
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
