can anyone tell me why TMPGEnc 3.0 XPress wont convert this movie file, here is what it contains File : 699 MB (699 MB), duration: 1:23:38, type: AVI, 1 audio stream(s), quality: 54 % Video : 630 MB, 1054 Kbps, 29.970 fps, 512*384 (4:3), XVID = XVID Mpeg-4, Supported Audio : 68 MB, 114 Kbps, 48000 Hz, 2 channels, 0x55 = MPEG Layer-3, Supported i have tried for days to get this to work even tried the tips of this site if anyone one can help id be greatful. also i have the 3iva codec pack installed on my pc
That audio doesn't happen to be MP3 VBR does it? That may explain it. Even if it isn't, you may be better off to save it out as a WAV with Virtualdub and use the WAV file for the encoder audio input. If it's VBR, Virtualdub will let you know right away. VD can also check the video for errors.
Not familiar with that codec pack, but generally installing any whole codec pack is a bad idea and can lead to codec conflicts. -
it does happen to be vbr but i did what you said and the output time is like 577 mins long
I've converted quite a few Xvids with VBR audio using VD to extract the WAV and encode with successfully. You might look to this to see if there is something you are missing:https://www.videohelp.com/forum/viewtopic.php?t=241895
The results you mention are common with encoding with VBR audio. Did you select the WAV audio separately from the video in TMPGEnc encoder? -
Load the video into virtualdubmod (or whatever variant of Vdub you use). When it offers to re-write the header, answer yes. You can then set audio to full processing, set the compression to uncompressed pcm, and save out the wav file. It will be the correct length.
Read my blog here.
http://members.dodo.net.au/~jimmalenko/ExtractAudio.htm may be of assistance. There's also a guide for doing this using virtualdubmod in the guides section - just select all guides written by me and you'll soon find it.
If in doubt, Google it.
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 9th Apr 2009, 23:56 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 28th Aug 2008, 23:33 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 00:17
