For the last couple of years or so I`ve used a wintv go card plugged into Sky+ digibox by s-vid cable and capping with windvr3. I found this to be an excellent method of analogue capping and of course windvr3 has the snapshot button to capture stills live. I recently bought a Twinhan dvb-s card (purely for price, prefer to lose out on £40 than £120 if I DVB-S wasn`t for me) pointing at Astra satellite (Sky digital) The bundled software isn`t that great and very often doesn`t recognise the cardbut when it does stills capping is a bit of a pain as you have to OK every still. I`ve tried both Progdvb and DVB Dream, both I find great for videos but again stills are a bit of a problem. Progdvb just doesn`t capture stills (get the windows error ping). With DVB Dream I get the noise of a camera shutter, but it doesn`t save stills anywhere, have done a thorough search of drive, but nothing. I`ve tried My Theatre, but It won`t seem to do a decent channel scan (good signal strength and cable on my setup).
At the moment I`ve been recording vids and taking stills from them using Windvd which is fine, but I was wondering if anyone knew of a piece of DVB-S software that gives an option similar to Windvr3 or a setting that will capture every frame on record.
I had the same problem, so I end up with a workaround: I cap mpeg 2 as usual and then I load that mpeg 2 on virtualdub mpeg 2 and extract a frame from there.
Of course I would love a straight solution myself, but I don't know any for the sky digital subscriptors (you can't use altdvb either, this program don't decode NDS cards with a smartmouse)La Linea by Osvaldo Cavandoli
Excellent. I have tried this before but with no success. On further reading I found out about the lack of clipboard functions with XP so I downloaded a clipboard util. Works a treat, much better than snapping with windvr. Thanks.Originally Posted by SatStorm
I`ll give altdvb a try when I get chance. I only use the card for the free channels, so the decoding of NDS doesn`t matter, I use the Sky+ and a standalone recorder the subscription ones and the virtualdub method works well for for captures made onto disc as well. Thanks again
DVB-S/DVB-S2 Satellite Receiver with direct HD,SD/SDI output not HDMI
By rahemeen in forum DVB / IPTVReplies: 1Last Post: 19th May 2011, 05:38 -
I need help finding a good video editing software at a decent price.
By JoryWLU in forum EditingReplies: 1Last Post: 27th Jan 2011, 23:18 -
Decent Video Editing Software
By Deluge in forum EditingReplies: 9Last Post: 9th Mar 2009, 22:38 -
What's the B.E.S.T dvb-s Software?
By themaster1 in forum DVB / IPTVReplies: 5Last Post: 9th Apr 2008, 05:03 -
Need Decent Software for Live Viewing
By doveman in forum Capturing and VCRReplies: 0Last Post: 30th Jul 2007, 14:20
