Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    Oct 2005
    I'm trying to capture LP vinyl to my hd using Audacity through a the M-Audio card.. I hear the audio fine.. But Audacity is not recognizing the card and I can't capture/record?? I tried updated drivers, made sure my line in was activated (and not muted). Any suggestions how do I get Audacity to work with the card? thanks.
  2. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    If you haven't seen them, there are guides and FAQs here: http://audacity.sourceforge.net/help/documentation
    Oct 2005
    Thanks much.. I did go over all FAQ's, troubleshooting, tips.. and still nothing.. I've adjusted all settings in Audacity to reflect M-Audio card.. I've selected line input of the card, made sure it wasn't muted.. checked M-Audio card settings, etc.. ??? When I hit record in Audacity, all i get is a flat line (even with line input selected).. very frustrating..
    I was able to record from the onboard audio easily prior to installing M-Audio card.. I've shot an email to Audacity help.. but thought I'd give it a shot over here too in case someone else had encountered the same issue..
