hey
i have audio problems when i try to convert:
first i used TMPGEnc but that didnt work cause i didnt get any audio at all. So i used VirtualDub to convert my audio bu then my audio is about 3 seconds behind the video.
HELP PLEASE
MERRY CHRISTMAS
make sure you select lock audio to video in setting on virtual dub.
once you load your file, or select capture avi, you select it under setting under the options tab.
go to the guide here under avi capture using virtual dub and you will see a pic on where it is.
Converting MKV to Mpeg2 audio problems
By anfield7 in forum Video ConversionReplies: 1Last Post: 22nd Feb 2010, 07:39 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 21:18 -
Help! Converting mkv. to mp4 (dual audio problems)
By ir0n_ma1den in forum Video ConversionReplies: 1Last Post: 5th Jun 2008, 14:50 -
Different converting problems
By saiden22 in forum Video ConversionReplies: 3Last Post: 2nd Jan 2008, 12:29 -
mencoder converting realmedia files w/audio sync problems
By kruuth in forum Video ConversionReplies: 9Last Post: 26th Sep 2007, 15:34
