DVD Lab allows for a delay to be added. If it is out by the same amount as before, add the delay again.
I have an AVI file source. The audio was playing before the video so i edited it in Virtualdub and applied audio skew (800ms)this fixed the avi and played fine.
I also change it from 44100 to 48000 for DVD purposes. I have then converted it in TFM creating seperate VIDEO & AUDIO files so i could author them in DVDLab. Since doing this the audio is out of sync again any ideas what could of caused this??? I have changed it from NTSC to PAL, which i do with all my avi's and never had a problem before. Do you think I should skew the audio once it is converted? Also is there anyway I can apply changes to my authored dvd?
Cheers Jim
Broken or not broken hard drive?
By romanstopme in forum ComputerReplies: 3Last Post: 17th Sep 2009, 12:04 -
Can this blend be fixed?
By alcOre in forum Newbie / General discussionsReplies: 8Last Post: 20th Jun 2009, 13:02 -
Can video corruption flaws be fixed?
By kayumidome in forum RestorationReplies: 9Last Post: 5th Apr 2009, 11:54 -
Can vertical oscillation be fixed?
By davexnet in forum Video ConversionReplies: 11Last Post: 19th Feb 2009, 20:11 -
by looking at this picture can it be fixed?
By effects in forum RestorationReplies: 4Last Post: 27th Aug 2007, 15:01
