Can anyone help me? I'm getting a lot of files emailed from work that are viewed in snap shot viewer, can they be converted to something like JPG so I don't have to keep opening them, plus I could scroll through them as jpg's.
If so, what program would I use? Thanks.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
I use the Snapshot function in my M$ Access database here at work... the function basically takes your report and outputs it as a snapshot file that can be view by anyone with the Snapshot Viewer (freeware from M$).
http://www.microsoft.com/downloads/details.aspx?FamilyID=b73df33f-6d74-423d-8274-8b7e6...displaylang=en
JSBOverview
The Snapshot Viewer enables you to view a report snapshot without having the standard or run-time versions of Microsoft Access 97 through Access 2003.
System Requirements
Supported Operating Systems: Windows 2000; Windows 95; Windows 98; Windows ME; Windows NT; Windows XP
This download works with the following Office applications:
Access 2003
Access 2002
Access 2000
Access 97
Download Size: 1795 KB -
Thanks, but I'm not getting a problem viewing the files, it's just slow and time consuming opening them. However, I have now solved the problem by making a snap shot with SNAGIT and saving as JPG. I can now scroll through them quickly.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
Something like Acdsee maybe ?
SpotCut - Detecting shot cuts from video files
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 27th Aug 2011, 12:15 -
16:9 shot, but 4:3 in DVD Architect.
By zovx in forum Authoring (DVD)Replies: 25Last Post: 14th Oct 2010, 09:46 -
automatic shot by shot video cutter
By monks19 in forum EditingReplies: 4Last Post: 26th Oct 2009, 20:17 -
What shot is this called?
By Chippy in forum Newbie / General discussionsReplies: 4Last Post: 18th Apr 2009, 00:47 -
AVI2DVD will not capture snap shot
By dkinney in forum Video ConversionReplies: 3Last Post: 18th Apr 2008, 19:43
