I'm really at a loss here. Our church records our services in DV straight to an external HDD, in approx 2GB chunks. I brought the drive home and I exported to files with USB to my pc. I need to figure out how to merge the 9 native DV type 1 files together before I start encoding them to DVD. Everything I've tried about encoding them all seperately and then putting them back together always results in an audio sync issue. Please help.
God Bless
von
Results 1 to 13 of 13
Use Virtualdub
open the first file, then
file --> Append AVI Segment
and continue adding the files.
Then frameserve to encoderMelde Melda Vessė
Eruanna ar Eruntano Melda Eruntanohini
"May your days be bright and contact with stupid people limited." -
Convert them to type-2 and use Avisynth or virtualdub as frameserver to your mpeg encoder.
VBub can't read Type-1 audio, therefore first convert the files. Then open first normal and the rest with 'append avi". Save the audio as wav. Convert the video via frameserv and convert wav to mp2/ac3 or leave it as pcm.
Remux later with the Authoring SW. -
Hi von_,
Welcome to the forums.
You should be able to join ("append") the files in VirtualDub.
That said, I'm surprised that a DV source leads to audio synch issues. Describe the tools and settings you're using to encode and author - that might highlight something.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I don't know if it does - I have to confess that I missed that bit. Even so, easily addressed with DV Type 1 to DV Type 2 Converter.Originally Posted by DragonsfThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Looks like VD added DV-Type 1 compatibility with 1.6.0.
It's nice to see such a useful freeware program being updated.
Now if they can just get it to transfer DV directly from a DV device.
As this is obviously a newbie issue (who else would write DV files to a FAT32 HDD
), I'd expected the next question would be about VDub type-1 DV audio complaints.
It can, but you wouldn't like it. (Lots of dropped frames and audio sync issues)Originally Posted by redwudz -
Just to highlight a few things (not necessarily clear)
If your pc runs an OS like Win95/98 or WinME, you re out of luck: the maximum file size for these is 2 GB per file (Fat23). You will not be able to merge the files into one (you could run an avisynth script and frameserve to an encoder, but beware the 2 gig file limit again at the encoder level). Best bet would then be to do all this on a machine that can accomodate NTFS (WinXP for instance) since it does not have the file size limitations.
I am also surprised at the synch issues. Do the files themselves sound out of synch before encoding? What encoder are you using? -
A lot of pre-built machines ship with XP on FAT32 formatted drives. Mostly because they were put togther by people who either a) don't know the difference, b) think NTFS makes programs crash (I know IT support people who swear it's true), or c) because they booted of a Win98 disk and used a cheaper upgrade copy of XP to build.
Read my blog here.
merge 2 subtitles files
By massimo.max in forum SubtitleReplies: 15Last Post: 29th Dec 2012, 03:35 -
Is it possible to merge iso-files
By dazler in forum EditingReplies: 7Last Post: 6th Jan 2012, 05:29 -
Merge two FLV files
By goheadtry in forum Newbie / General discussionsReplies: 19Last Post: 16th Dec 2010, 22:34 -
How to merge wav files ?
By Benjy in forum AudioReplies: 7Last Post: 31st Jul 2010, 05:41 -
How can I merge two video files into one?
By DVDNewb in forum Newbie / General discussionsReplies: 24Last Post: 17th Mar 2008, 14:58
