greetings,
recently I downloaded a movie from a friend that was authored in a weird fashion. the movie itself had been embedded with TWO audio tracks! one english, one spanish. the instructions were to use VLC player and go to Audio -> Track -> track 1 or 2
As I don't speak spanish, I'd like to remove the spanish audio from the movie entirely.
is there a simple method of doing so, or must I re-encode the entire movie? if so i will, but i'll need a walkthrough of sorts.
Thanks,
Jay
ooopppss...sorry for the last post, I donīt know why I assumed it was in DVD format...if itīs DVD try my suggestion, if not, I hope somebody else can come up with the proper solution.
Assuming its an AVI file. Open the file in VirtualDubMod. Goto Streams > Stream List. Select the audio stream you dont want and click disable.
In the video option select Direct Stream Copy and save the file again as AVI with a different name. The new file will not have the disabled audio track.When I was born I was so shocked that I could'nt speak for 18 months.
BATCH remove audio track from mkv
By MarquisdeOz in forum AudioReplies: 53Last Post: 30th Jul 2018, 09:48 -
How do i remove an audio track from an AVI file?
By alih786 in forum AudioReplies: 51Last Post: 29th Nov 2016, 07:31 -
How to remove audio track?
By MAAG in forum AudioReplies: 13Last Post: 13th Jun 2012, 19:19 -
Movie maker -- remove audio ?
By mister in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 6th Jun 2009, 13:48 -
how can i remove wind noise from a audio track
By suomiaussie in forum AudioReplies: 2Last Post: 23rd Mar 2008, 10:10
