Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    Jun 2005
    USA
    I usually use WWM2 to edit the videos, but if I want music for certain frames and source audio for other frames and also both in some other frames, I can't do it in the same .avi file.
    So either the whole file is with music or source audio as is or both in WMM2. So is there any freeware that I can do both of them or only music depending for particular frames in the same avi file??
    Many thanks
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Put the music audio on the separate audio/music track. You can fade the music track in or out and adjust mix volume with a right click on the audio track.
    http://www.kiva.org/about
    Jun 2005
    USA
    Thanks edTV,
    I understood what u mentioned. But the audio/music track or the adjusting volume levels is not confined to just one frame, but for all the frames in the avi file. So for all the frames, the adjustment levels are the same. I wanted the file audio to be there in one frame and only music in another frame.
  4. Member edDV's Avatar
    Mar 2004
    Like this? Main track is muted. These types of edit are so much easier in Premiere.
    Jun 2005
    USA
    Ummmn......yes, will try in premiere then.
  6. Member edDV's Avatar
    Mar 2004
    The rasor tool in Premiere makes short work of dividing tracks. Audio levels can be keyframed.
