I have a modded xbox but can't seem to figure out how to play the files from my pc.
XPMC is installed.
I have the pc and xbox hooked up direct (no router). The pc is not connected to the net so there is no virus software or firewall running.
I can't figure out how to access my pc hard drives and get a directory to play the files.
Anyone have any advice...a link to a step by step?
On another note...has anyone used the 360 for this yet? How is is?
Results 31 to 35 of 35
Originally Posted by lordhutt
[quote="starwarrior29The 360 has a tab with media center in it, no modding needed. [/quote]
Does it have the interface to view movies by type, cover art, etc? Same for CDs.Thanks
Roger -
It has a view of your folder from your computer with all of the files in it listed that can be sorted by name or date. Currently most wmv and mpeg files are supported, there is a program called transcode 360 that decodes divx from your computer to the 360 on the fly, apple quicktime movies are not playable though and you would have to convert those if you wanted to watch them on the xbox.
You mentioned in your previous post that 'all' video can be streamed to your 360. Now you said that Quicktime cannot. How bout xvid?
I am not concerned about the games...just playing mostly video.
Does anyone have any experience with this unit:
http://hometheater.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=hometheater&zu=http%3A...ne%2Fx5000.asp
Windows Media Center on Xbox 360 - how it works and codecs help!
By prankstare in forum Media Center PC / MediaCentersReplies: 6Last Post: 5th Feb 2011, 09:29 -
XBOX 360 media center bandwidth requirements
By Darth Paris in forum Media Center PC / MediaCentersReplies: 18Last Post: 4th Feb 2011, 13:39 -
Best All Around Codec for Xbox 360 Media Center Extender
By dohclude in forum Media Center PC / MediaCentersReplies: 7Last Post: 26th Jun 2010, 13:37 -
DVD to Windows Media Center Extender on Xbox 360?
By md3699 in forum DVD RippingReplies: 0Last Post: 26th Sep 2009, 19:23 -
Sharing TV - 1 Vista Media Center Server to Vista Media Center PC
By JBredensteiner in forum Media Center PC / MediaCentersReplies: 8Last Post: 14th Jul 2007, 01:33
