Ok let me start,
I'm getting an AC3 error when I try to output my converted AVI into VoB's from Tmpgenc DVD author.
These are the steps I have taken:
First convert AVI into VOb's with Imtoo Mpeg encoder
Then use Tmpgenc DVD author to output the Vob.s
Then I get an error? I have done this before Flawlessly with out the error. I have no idea what is going on?
Can someone help me?
TIA
Results 1 to 10 of 10
Why is it, people all of a sudden insist on feeding VOBs into authoring apps? VOBs is what an authoring app creates!
Back to the problem at hand - How was the AC3 created?
/Mats -
Originally Posted by mats.hogberg
I have been doing it for a looooong time 8)
Like when you have a video/movie only, already in vob's and want to make menu's, and load them into TDA
@ Ttex
If you are just converting .avi's to vob's, is the original avi audio dvd compliant before or after converting them ? -
Yes the AVI does have sound.
The exact error message is ( (Illegal Dolby Digital (Ac-3) Stream?
No Idea man
Thanks -
Originally Posted by Ttex
8) -
converting into vobs is a waste of time, as TDA will just have to demux the audio and video out before creating it's own vobs. Just output either a program stream (.mpg file with both video and audio in it) or elementary streams (a seperate file for video and audio).
How did you create the AC3 audio file ?
Or did it come with the avi ?Read my blog here.
The audio and video are included in one file that can be played on WinMedia player. Tmpegenc DVD author does not read AVI. So I use Imtoo encoder to change into MPG.
Thanks -
Actually, you should be demuxing it, converting it in somthing like TMPGEnc for the video, audio blah blah blah... but instead of answering Q's you just seem to have a case of the giggles -
To get off on the right foot, I suggest you look under CONVERT left for AVI to DVD guides.
Basically, if you have an AVI with AC3 audio, you start with demuxing the AC3 stream (and run it thru ac3fix), then encode AVI to DVD specs m2v video only, then author AC3 + m2v.
/Mats
eac3to: error converting 6.1 ch DTS -> AC3
By KushSmoka420 in forum AudioReplies: 5Last Post: 6th Mar 2012, 10:35 -
Dolby Digital PLus (ac3) track to FLAC error
By Edgarke16 in forum AudioReplies: 0Last Post: 26th Sep 2011, 23:38 -
error compressing AC3 in virtualdubmod
By dudubitn in forum Video ConversionReplies: 1Last Post: 27th Jan 2010, 17:40 -
GUI for dvdauthor AC3 error
By rancid in forum Authoring (DVD)Replies: 6Last Post: 3rd Jan 2008, 23:25 -
5.1 AC3 to 2ch mp3 error's in VDubMod
By Sykotik in forum DVD RippingReplies: 0Last Post: 20th Oct 2007, 06:53
