Hello,
My main computer is now a laptop, with wireless internet. Would it be possible to take the wireless internet I am getting and share that over the ethernet port of my computer? I would like to hook my x-box up to the network, but the router is too far away, and I don't want to buy the xbox it's own wireless card. Is it possible to share my w-fi connectioin via my ethernet on my laptop?
(win XP, SP2)
Should be able to do this.
You'll need a crossover cable between your laptop and your XBOX to start with. Then your XBOX will need to be in the same IP range, specifying the IP of the laptop as the gateway. Then there'll be something you need to do on the laptop to enable ICS (internet connection sharing).If in doubt, Google it. -
I think you'll need to set up a "network bridge" on your laptop between the wireless LAN and the wired LAN... WinXP help files/wizard should be able to help you.
Regards.Michael Tam
w: Morsels of Evidence -
thanks for the information. The bridge worked...but I got an error because of incompatable IP addresses. How do I find out what my Xbox IP is, and how do I change my laptop Ip to match it?
N wireless or Panasonic Ethernet adapters?
By neworldman in forum ComputerReplies: 2Last Post: 4th Apr 2014, 08:44 -
Wireless Internet Connection Questions
By hech54 in forum ComputerReplies: 11Last Post: 28th Nov 2011, 09:38 -
Share my Internet connection (like a proxy)
By themaster1 in forum ComputerReplies: 13Last Post: 25th Aug 2011, 23:00 -
No Ethernet port and wireless adapter but want to connect HS Internet
By coody in forum ComputerReplies: 1Last Post: 11th Dec 2009, 13:57 -
Newly installed ethernet card into old PC w win98, no internet connection?
By Denvers Dawgs in forum ComputerReplies: 17Last Post: 10th Jan 2008, 09:55
