  1. i had burned a file into a DVD+R and then i tried to copy the file back to my computer but i didn't work, it said:
    CANNOT COPY XXX: DATA ERROR (CYCLIC REDUNDANCY CHECK)
    why is that?
    i've never experienced this before
  2. Member ashtones's Avatar
    Aug 2001
    Bad disc. Most of the time that is what this error means. Just to make sure clean all of the dust and fingerprints off of the disc.
  3. Originally Posted by ashtones
    that means if i clean it, i can copy the file?
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Maybe, maybe not.
    Sometimes yes, other times no. Depends.
    All you can do is try it.
    If in doubt, Google it.
  5. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Which brand of DVD+R have you used. Sometimes inferior brands can cause this problem too. Always buy good branded media.
  6. Member ebenton's Avatar
    Jul 2003
    The WINDY state (Florida)
    Most set top DVD players will play disks with read errors. They skip over/ignore the errors, in most cases. However, most copy software will not ignore read errors. So when you try to copy a disk with read errors on your PC, the copy program cannot continue when it encounters these errors.
    One exception to this behavior in copy programs seems to be DVD Fab Decrypter. It may take significantly longer to copy, but it will copy *many* disks with read errors. Try DVD Fab Decrypter. It might work. Like I said, be prepared for a slower process.
    To avoid this in the future, check your disk copies for read errors immediately after you copy them. Also, don't buy blank DVDs that don't work well with your burner. Find out which DVDs these are and stop buying them.
