i have an HDTV avi file that I'm fooling around with, trying to find the optimal encoding settings to fit 3 of them on one DVD, and also having the picture be clear.
The first time i encoded, i did 1-pass CBR @ 6,000kb/s with 16:9 aspect ratio
the quality was good, except it didnt fill the screen, it had a black border all around it.
I checked Frame Size [resize 720x480] and re-encoded.
Fills the screen now! But there are frames with out of place colour boxes, such as green or other bright colours. I've tested it and it only happens when i check resize, regardless of bitrate
how can i get around this?
Use virtualdub or avisynth to frameserve to CCE, rather than using CCE's resize. I do this all the time with no ill effects. Also, CBR 6000kbps for my money is getting on the low side. I would use 2 pass VBR with 6000 as the average and max/min of 8600/2500
Read my blog here.
i have virtualdubmod, but do not use it because i am clueless as to how.
How is 'frameserving' achieved in virtualdubmod? -
https://www.videohelp.com/virtualdubframeserve.htm
Pretty much the same for all varients of virtualdubRead my blog here.
AVI to DVD MPEG (CCE or TMPGenc encoders)
By DJRumpy in forum User guidesReplies: 674Last Post: 15th Oct 2010, 07:46 -
Encoding 16:9 Widescreen MKV using CCCP pack and CCE results in 4:3 MPEG 2
By octagon69 in forum Video ConversionReplies: 21Last Post: 17th Oct 2008, 20:52 -
Looking for an MPEG-2 Encoder like CCE and FFMPeg Questions
By Maikeru-sama in forum Video ConversionReplies: 85Last Post: 31st Aug 2008, 23:24 -
MPEG-4 to MPEG-2 using CCE 2.50 OPV: How not to waste bitrate?
By Fran-K in forum Video ConversionReplies: 5Last Post: 4th Apr 2008, 07:38 -
Problems with mpeg after conversion, or with original avi - help
By krisbee in forum LinuxReplies: 1Last Post: 30th Oct 2007, 16:56
