many of the disks I've been writing have a problem playing back. playback gets "stuck" sometimes temporarily but eventually it can't play anymore. this most usually happens towards the end of a movie.
the situation does seem to be improved if I play it in on my computer as opposed to my set top dvd player.
I'm not sure if this even has anything to do with ffmpeg but has anyone else had this experience? any tips or ideas what it could possibly be would be appreciated.
If you are using ffmpeg to encode, such as in the "DVD ffmpeg" preset, it sounds like your problem could be do to the fact that ffmpeg is not truly a constant datarate encoder: your "stuck" could be the data spikes causing trouble on standalone dvd players.
Either re-author your movie with Toast, ie have toast re-multiplex it because toast since 6.0.7 tends to even out these data spikes. Or, try re-encoding your video using mpeg2enc such as in the "DVD mpeg2enc" preset.
*If the playback problems are happening on your computer, this is likely not the problem.*
Cheers,
Alph
Vista DVD Playback Problems
By JMMac in forum Software PlayingReplies: 14Last Post: 16th Dec 2010, 13:39 -
Divx playback problems on DVD Player
By pblunn in forum DVD & Blu-ray RecordersReplies: 4Last Post: 26th Feb 2008, 02:02 -
Laptop DVD Burner Playback problems
By Cake^^ in forum DVD & Blu-ray WritersReplies: 3Last Post: 11th Jan 2008, 05:48 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 09:19 -
By thelethal in forum Video ConversionReplies: 7Last Post: 4th Jun 2007, 14:08
