I recorded some files to a few DVD-RW's on a Sony burner about 6 months ago. I have a new computer with a Sony DRU800A and it doesn't recognize any of the disks. As a matter of fact, the older PC was reformatted and even that Sony burner won't recognize the discs now either. DMA is enabled but still nothing shows up.
Is there some software for rewriteables that has to be installed? My new drives were OEM and didn't come with anything.
You might be missing software for DLA ( drive letter access ) which allows you to treat a dvd like a large floppy. I use it for dragging and dropping files to dvd-rw's. Mine came with a Sonic program.
Click on My Computer and then right click the dvd drive icon. Do you get a display like below? Click on "Use with DLA" to enable it.
Thanks. I had to install Veritas DLA from my older burner's install disc so it is enabled now. The OEM Sony burners that came in my PC from TigerDirect had no install discs and nothing was to be found at the Sony website.
Oddly enough, several Memorex DVD-RW's are accessible but none of the Sony DVD-RW's can be viewed. They don't even show up on the old Sony burner I originally created them on. I hate to lose all the stuff I backed up on them. Any suggestions for getting access to them would be appreciated. Once (if) I recover my files, I'll never use RW's again!
PAL/NTSC DVD/VCR combo that will play DVD+R's w/o A/V synch problems?
By wetcamelfood in forum DVD & Blu-ray PlayersReplies: 12Last Post: 12th Jan 2010, 16:25 -
DVD-Lab Pro: DVD-R DL burning problems
By jonghyunchung in forum Authoring (DVD)Replies: 3Last Post: 14th Dec 2009, 07:57 -
DVD Editing from Panasonic VDR-D220 Mini DVD and interlacing problems
By gbnz in forum EditingReplies: 3Last Post: 15th Oct 2008, 14:34 -
Sync problems while authoring a DVD with DVD Flick
By TioSolid in forum Video ConversionReplies: 1Last Post: 16th Aug 2008, 13:21 -
Help with audio problems on dvd-lab pro and / or subtitles on a dvd
By Jack the Ripper in forum Newbie / General discussionsReplies: 12Last Post: 7th Dec 2007, 18:00
