i'm trying to split movie by limiting the number of frames per segment
the problemsi that the most of the output clips are corrupted for some reason.....
i'm using wmv 9 compression with default settings....
any ideas?
Have you tried using windows movie maker ?
In windows movie maker , import clip , then File , "save movie file"
Save to "my computer" , then next , followed by name of file .
In next box to show , there is a blue text line "show more choices"
Click it , then "other choices"
Chose ouput "high quality video" , for me its pal (au) , then next .
The file can now be edited by using virtualdub to how you want it .
You can then re-encode to wmv9 by importing each clip into windows movie maker and drop one at a time onto the time line and output it , then remove that one from the time line , and repeat the process till you have converted each clip .
I used to have to original encoder utility here , as it allows choice of codec , however , windows movie maker dosent say which it's using , just wmv ... -
thanks Bjs, but the problems is that the source files are mpegs, and i use virtualdub-mpeg to edit them, but the "save as segmentet AVI" option just doesn't work for me
and i'm using wmv9 compression for the output files
Is there a way to save a Virtualdub filter chain?
By groove365 in forum Capturing and VCRReplies: 5Last Post: 3rd Sep 2010, 23:20 -
FLV Input Plugin for Virtualdub lets you save as AVI with no quality loss?
By gumbygum in forum Video ConversionReplies: 7Last Post: 1st Aug 2010, 14:08 -
VirtualDub....save as .mp4
By Ogilvy in forum Video ConversionReplies: 2Last Post: 19th Mar 2010, 23:29 -
VirtualDub: Saving Segmented Avi
By Ruro Jiruries in forum EditingReplies: 0Last Post: 18th Jun 2009, 07:13 -
Can VirtualDub save DV-AVI's?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 21st Oct 2008, 09:10
