I shot our recent trip to Thailand on a Sony HDR-HC1 at the camera's
highest HDV 1080i resolution (1440 x 1080).
I now want to share the edited version with friends and my extended
family, most of which own HD capable televisions.
How can I burn DVDs that will play at the full-resolution 1080i on their TVs?
What's the point of shooting in HDV if I am forced to down convert
to regular 740 x 480 DV resolution to burn a DVD? I might as well
just have shot it on my old Sony VX2000, which is far superior in
low-light to the HDR-HC1.
Any advice appreciated,
Zen
Results 1 to 10 of 10
Simple answer, you can't. Maximum DVD resolution (NTSC) is 720x480. The only thing you can do is archive the original video and wait until one of the High Definition formats is out (HD-DVD or Blu-ray).Originally Posted by Zen of Encoding
You could convert the file to Divx and burn to DVD but you'll need a DVD player that excepts Divx resolutions up to 1080. There are a few out there.
Chas -
That's hitting the nail right on the head.What's the point of shooting in HDV if I am forced to down convert
The camera companies will not mention THAT little secret!!!
You can only output to file or to tape. and that you can then play out to your TV if you have the right connections.
That's it! No DVD format you can go out and set up today will allow you to play at that rez. Will have to wait till that part of it comes to us. We hope!No DVD can withstand the power of DVDShrink along with AnyDVD! -
Until HD DVD players become widespread, ... maybe in 5-7 years, you will still need to downscale to DVD distribution copies.
In the meantime, the burden is on your distant viewer to buy a specialized MPeg4 player (for DivX, WMV-HD, etc.) or rig a computer to play HDTV files to a HDTV display.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
You could check out DVHS.
Another option is to convert to .ts and burn that to a data DVD. You'd have to playback on a PC.
Darryl -
Zen of Encoding,
Just courious as to what file format does the HDR-HC1 capture?
dphirschler,
There are DVD players that will accept .ts files but they will be limitted to about 40 minutes per single layer disc.
Chas -
There is a way to encode HD video with DIVX 6 to full 1280 x 720 and then simply burn to DVD as a data disc, There is also a disc Player that will play these files directly to your TV. Have a look at the Divx.com site for info. I've seen some of the sample files and they are glorious on the PC.
At least until we can burn HD discs it might be an alternative. By the way the sample files seem to range btween 30 to 40 Megs per minute.
Another way would be to set up a PC based media center hooked up to your HDTV and use a software based player that can handle the HD files.No DVD can withstand the power of DVDShrink along with AnyDVD! -
Yes, but ...Originally Posted by jtoolman2000
Zen wants to distribute his programs to friends and relatives in HD format. The only way is if these people buy a special DivX/WMV DVD player or rig a computer for HDTV playback from files.Recommends: Kiva.org - Loans that change lives.
Well I guess that's what I meant to say.
HV40: Record in HDV(PF24) vs HDV(24F)
By videobread in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 23rd Dec 2011, 20:44 -
1024 576 resolution not full screen in mpc
By mrwonker in forum Software PlayingReplies: 4Last Post: 18th Jul 2011, 15:40 -
External Hard Drives...How Full Is Too Full?
By bbanderic in forum Newbie / General discussionsReplies: 5Last Post: 17th Mar 2010, 17:25 -
Is it possible to get full 16:9 resolution and when...
By FrancoAnselmo in forum Newbie / General discussionsReplies: 12Last Post: 19th Jun 2008, 16:48 -
From HDV shooting to HDV watching
By MI6 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th Apr 2008, 13:05
