first, what does region free mean?
ok, i wanna play my computer files on my tv, i understand the hookup to the computer, but for a tv with just a coax, what do i do? can i use my vcr? arg. plz help
Region Free means that you can play DVD's from any country you bought it from.
You will need a TV card or a Display Card with TV-Out, you can connect it to either your TV directly or to your VCR, and play
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
on the back of the vcd, is there a video in with just one hole instead of the daul rca's, same with sound?
On the back, you should have one RCA for the Video In, and for the Audio, you will need a Dual RCA to Jack cable, the kind that used to come with the old Sound Blaster (2.0/Pro/16/AWE) cards.
Best Regards,
Sefy Levy,
3 options...
#1 you can make vcd's and get a dvd player (make sure it plays cdr's)
#2 get a video card with a TV out and use that and the line out on the sound card to connect to a vcr (requires a vcr with 3 rca jack input or audio input and s-video input)
#3 get a scan converter (generally better than tv out on the video card) and connect the same way you would with a tv out on the video card.
some searches on this forum can offer lots of advice on any of the above methods.
peace out,
dumwaldo
AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose.
MKV file audio out of sync on my computer, inferior computer plays perfect
By dave in or in forum Newbie / General discussionsReplies: 7Last Post: 5th Aug 2011, 21:56 -
How to copy dvd movies to computer and build a liabrary on the computer
By robrpb in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2010, 18:16 -
Computer Guys Braggin' Time: What have you built that AIN'T a computer?
By ahhaa in forum Off topicReplies: 22Last Post: 8th Feb 2010, 15:19 -
Compare VHS to computer vs cheap HD to computer ending in youtube post
By gittarpikk in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 12:06 -
Capturing Halo 3 gameplay from computer monitor to computer
By Jamo in forum Capturing and VCRReplies: 1Last Post: 13th Oct 2007, 00:06
