I am a newbie so I'm sorry if this is a dumb question. I am trying to compress a large mpeg file into one that can fit onto a single dvd, using DVD4 Tool. ( I am a registered user). I am not sure how to convert the mpeg file into a VOB file to use the tool. The Video_TS file has several VOB files but I do not know if those are the ones to use, and if so, how.
thanks for the help,
Jerry
Try to join those big VOBs by following this method and then compress the big VOB.
https://www.videohelp.com/forum/viewtopic.php?p=1056853#1056853
Thanks.
I also found a little program called D-Vision with a GUI interface that merged the VOB's automatically. and worked well.
Jerry
Can I copy a DVD9 to a DVD4??
By hzgg2 in forum DVD RippingReplies: 1Last Post: 10th Oct 2008, 14:56 -
Problem with dvd4 tool
By barskey in forum ffmpegX general discussionReplies: 2Last Post: 5th May 2007, 20:32
