Hi,
I have a project that I want to create a menu for it.
My project is widescreen NTSC 16:9 so I want my menu to have
the same aspect, but when I call the piece of video to have as a
background or any picture, it renders as NTSC 4:3.
Is there any way, setting or whatever that I can do to get the result I'm looking for?
Thanks for your help
Results 1 to 17 of 17
does TDA support widescreen menu's?
I know DVDLab Pro does -
TMPGEnc DVD Author does not support 16x9 menus.
I think that the new TSUNAMI MPEG DVD AUTHOR PRO version does but I'm not 100% on that ... I haven't upgraded myself just yet though I plan to eventually.
Maybe someone usig the new TSUNAMI MPEG DVD AUTHOR PRO can come along and confirm or deny it's 16x9 menu capability.
thought so
, thanks FulciLives for confirming it
I looked at the site but I can't see anything there or elsewhere about whether it supports it or not -
Originally Posted by MackemX
As soon as I get some extra money I will have to upgrade. 16x9 menus with additional audio support is just the ticket. No subtitle support yet but when I need subtitles I just burn them in the video image anyways which works fine for me since I need them (not like I need to turn them off).
- John "FulciLives" Coleman
P.S.
Here is that graphic from the TSUNAMI website.
Pro version does
http://www.tmpg-inc.com/product/tdap_spec.html
Editing functions -for DVD MENU-
Creation of 16:9 menus - For menus with 16:9 aspect ratio. The standard templates have been made to support both 4:3 and 16:9 menu resolutions. -
@GRAMOPHONE
Obviously the suggestion here is to upgrade to TSUNAMI MPEG DVD AUTHOR PRO if you want 16x9 menu design.
do programs like GUI for DVDauthor etc not support 16:9?
maybe he could create a menu using those and then replace it afterwards -
do programs like GUI for DVDauthor etc not support 16:9?GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
It is funny that this thread just got started. I am working on a HD > DVD conversion of Neil Young on Conan and just noticed this issue with the Menus being 4x3 in TMPGEnc DVD Author. This sucks! I do not want to have to drop more cash to upgrade just for 16x9 menu support. I really like the ease of use with DVD Author and have spent a lot of time getting the pictures for the backgrounds just the way I want them. Any suggestions that don't involve a ton of money?
Originally Posted by sullen
Buy My Books -
It will stretch the picture but I don't think it will stretch the subpicture so then the buttons will be out of place
saying that you could make it so that the buttons are out of position to begin with -
Well, I found the solution to my problem and the OP. After thinking about IfoEdit I decided to just give it a try and it worked. Just load your .ifos in it, click the menu(s), change the aspect from 4x3 to 16x9, save, and burn. There is some stretching with this tactic, but I would rather have stretching than mixed ARs.
that's cool sullen 8), though gadgetguy did mention this method so I hope you didn't think too long
can you tell me if the buttons stay in the same position relative to the image also? I was under the impression they wouldn't but I was probably wrong -
I uploaded two pictures to show the difference. The first screen cap is the menu VOB that TDA created. The second screen cap is the Menu as played using the IFO file.
http://home.comcast.net/~simms3/Neil4x3.bmp
http://home.comcast.net/~simms3/Neil16x9.bmp
Widescreen DVD menu overscan problem (only on older equipment)
By Grunberg in forum Authoring (DVD)Replies: 7Last Post: 15th May 2011, 07:39 -
Menu for Widescreen DVD
By cheerful in forum Authoring (DVD)Replies: 1Last Post: 6th Mar 2010, 21:39 -
Widescreen Problem When Capturing
By DW in forum Capturing and VCRReplies: 4Last Post: 26th Mar 2009, 05:46 -
widescreen dvd problem
By seanin in forum MacReplies: 2Last Post: 6th Jan 2009, 18:25 -
Encore widescreen menu question
By sky captain in forum Authoring (DVD)Replies: 0Last Post: 18th Sep 2007, 12:24
