I apologize is this is a bit off-topic but it didn't seem to fit anywhere else any better. I cannot seem to find an answer to this question anywhere else. Hopefully someone can help here.
I have a High-Def MPEG movie (1280x1088) on my hard drive that I would like to copy off to DVD. It is a bit over 8GB. It is my understanding that you have to have special drives that support HD-DVD for that, can I at least copy it to a "regular" dual-layer DVD as an MPEG file and maintain the quality? This will allow me to store it until I can get an HD-DVD burner.
yes you can save the file as data.
http://www.kiva.org/about -
As Ed said, but the file should be split up in 2GB chunks for best compatibility. Correct me if I'm wrong (and boy, am I wrong frequently), but most burning apps will insist you burn a DVD in UDF file format if any file is over 2GB. That's fine for most (but not ALL) systems. My only concern is compatibility, so I err on the side of caution and split the files up.
Most HD TV broadcasts run around 13MB/s. I am doing a lot of HD recording off of Leno, Conan, and SNL. That is with 2 channel AC3 @ 384. A good way to archive larger shows is to seperate it to multiple discs using a program like WinAce that will zip the file into parts that fit on the DVD, that is if you are planning to just archive and not play off the DVD itself.
After reading this and looking at a channel I saw that. Old SD material upconverted, Friends reruns, are showing as 19.1 where HD material is running 13 so the simulcast is in there. Wish they would run straight streams of HD content and give a little more to lessen the compression.
You can use HDTV to MPeg2 to extract a single stream.
http://www.midwinter.com/~bcooley/Recommends: Kiva.org - Loans that change lives.
DVD to an edited MPEG-2 file with MPEG audio: Trouble/please help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 9th Aug 2011, 08:52 -
Please help with backing up 360 games (ISO file is small)
By V Bot in forum ComputerReplies: 0Last Post: 13th Jan 2011, 22:27 -
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 11:11 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
Looking for advice on software for backing up my file server
By bigshotceo in forum ComputerReplies: 1Last Post: 7th Jul 2008, 10:50
