I've been checking some things, and using the DVD mpeg2enc preset in combination with mplayer decoding, you should get hard coded subtitles. The resulting mpg files should be easy to compile in Toast.
Results 31 to 43 of 43
Oh my Dear Case thanks. I was trying things but nothing really worked, even I was tempted to go to the dark side, but here you are with a new solution to try.
So let see if I got it straight DVD mpeg2enc with mplayer, all the other tabs, audio and subtitles the same as you told me before?
I big kiss and thanks again,
Huifa."Everything happens for a reason" -
Originally Posted by Manolo
It's great that you are interested in this stuff and are taking part in discussion here, but you posted this 17 hours after asking your question.
I think you are expecting too much if you expect an answer in that time. Please recall that everyone who is answering your questions is doing so for free and on a voluntary basis. If you get an answer, then great. If you don't get one, don't complain. -
Originally Posted by thoughton
I am very sorry, and promise that won't happen again. Thanks for taking your time to tell me.
Cheers lads,
M.
PS: By the way new ideas have arrived. -
No problem Manolo, just a friendly reminder
I hope Case's solution works for you. I haven't done anything with subtitles for a long time now, so I'm letting him answer all the tough questions
PS I don't suppose you are the same Manolo who writes a very funny blog about shoes? -
Case:
I just finished the process with ffmpegX as you told me to get the hard coded subtitles with DVD mpeg2enc preset in combination with mplayer decoding.
But I am confuzed, I got a few files from that process:
One .avi.ff.mpv with movie and no sound,
other .avi.ff.mpa with sound and no movie,
other .avi.ff.mpg with movie and sound but no subtitles, I played it on VLC, Xine and QT but could not find subtitles anywhere.
Did I miss a point?
Sorry to be such a bother but i do not know how to get the results and I think I have been very carefull following instructions.
If you have more suggestion i'll be glad to try them.
Best wishes,
tracking down the steps of Case The Explorer I finally get a solution.
Originally Posted by Case
Originally Posted by major
Now I get my .avi with harcoded subtitles so I can burn them into DVD keeping the original AC3 audio.
But this could not be possible without the always helpfull Case, and the contribution of others who add tips in the process.
So to you Case a really big kiss and the most sincere thanks for you patience.
Best wishes,
Huifa. -
It seems like a happy ending.
I got the answer that I needed from this topic thanks to Case, Huifa, Thoughton and the others who died trying to bring in an answer (keeping the drama).
Cheers Lads and Lady,
M
PS: Blog about shoes? No it's not me. -
Originally Posted by Huifa
(If you had set for AC3 audio, then you would have had an .ac3 file instead of an .mpa file. But that is not related to subs.)
The reason for missing subs may be because of your ffmpegX setup. I can't think of anything else. Are you running Mac OS X 10.3.x or 10.4.x? Is your ffmpegX version 0.0.9t r4? Did you install the matching binaries as indicated by the Install binaries window?
Check this: Set ffmpegX up for encoding your movie, including setting the subs (Filters>Subtitles>Load subs). But instead of clicking Encode, click Play (top, right). Do you get subtitles then? -
Originally Posted by Huifax
I'm glad you got it working. If you can spare a shareware donation, then don't forget the author of ffmpegX.
http://shoeblogs.com/ -
Ok i know this is a lot of encoding but this is how i get my Tv episodes (AVI) onto DVD
First start by opening toast 7...under the "Video" tab choose "Video CD"
Drop in the episodes..it doesnt matter if the little coloured bar at the bottom goes into the red at this moment in time
Now goto "File" And "Save as Disk Image"..Save it somewhere..After it has encoded, right click and "Mount it"
Now open the Disk image and goto the "MPEGAV" Folder ...You should see your episodes there...they will be called "AVSEQ01.DAT" files
So depending how many episodes you dropped in you'll have as many .DAT files
OK now copy the .DAT files out onto your desktop and rename them to your TV show.
So....
If you dropped in 3 lost eps
AVSEQ01.DAT=Lost Eps 01.DAT
AVSEQ02.DAT=Lost Eps 02.DAT
AVSEQ03.DAT=Lost Eps 03.DAT
And so on......
Now open up toast again and under "Video" tab choose "DVD-Video" and drop in the .DAT files...keep your eye on the little colouerd bar so you know when your DVD is full.
Choose the menu style you want and Goto "File" and "Save As Disk Image"
Once this has encoded you will be able to burn the image to a DVD and watch on your Player
Guys i know that there must be easier ways of getting .avi files onto DVD but this has always worked for me and with my new GigaDesigns 2GHz processor upgrade for my G4 it doesnt take long at all
About 20 mins to encode an episode to VCD then about 1 and a half hours to encode a full DVD
And please dont ask me any hard questions as i dont pretend to be a Encoding whizz...in fact i stumbled upon this by accident
I hope this helps you out -
Great tutorial res1492,
by the way do you know if your proccess works with HR.HDTV.AC3.5.1.avi ?
Thanks,
M.
New Tool: Combine TV MKV Episodes auto creating chapters
By kingfetty in forum Video ConversionReplies: 1Last Post: 21st Feb 2014, 13:15 -
Need to convert TV episodes from DVD to AVI
By perceptionist in forum Video ConversionReplies: 23Last Post: 17th Feb 2012, 22:53 -
I am sure I am a twit but...DVD episodes to avi files
By cheerychops in forum Newbie / General discussionsReplies: 9Last Post: 5th Aug 2010, 09:39 -
How to convert DVD TV episodes to AVI Xvid or MP4 H264 with subtitles
By Baldrick in forum User guidesReplies: 9Last Post: 5th Jun 2010, 02:06 -
Creating dvd video with 20+ episodes of anime
By kurt_tml in forum Authoring (DVD)Replies: 9Last Post: 21st Jul 2008, 18:26
