I am useing Adobe Premere Elements. When I export my movie the quality of it goes from 10 to 3. I put a fine clear video in and then I edit it, and export it and when it is done it looks like crap. Is there a way to help the quailty?
What are your encoder settings?
Something is wrong with the way you are specifying output encoding.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I don't have Elements
There should be some kind of output selection menus. Normal Premiere gives default DVD encoding choices of 7Mb/s CBR or VBR. Start there .Recommends: Kiva.org - Loans that change lives.
is anything in your video static images? I know that premiere tends to have a somewhat rough time with these and it ends up kind of "jaggy" in the final video. I have yet to find out how to clean this up though.
in any case, I would go with what others have suggested here. one extra suggestion I would try is using the "Adobe Media Encoder" here you can export to DVD quality mpeg2 if you wish. -
I'm not sure if Elements will let you do this. But best practice, is to always make a avi file of your project and encode outside of the timeline. Look for an Export Movie. Then make sure your settings are for DV AVI. Save the file. Close Elements, Open whatever MPEG2 encoder you have and encode.
Use your head, Side Step the Traps, Snake through the chaos with a SmoothNoodleMaps
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 03:17 -
adobe help!
By alintatoc in forum Off topicReplies: 4Last Post: 14th Apr 2008, 04:45 -
Adobe Encore Help
By Entengdigital in forum Authoring (DVD)Replies: 0Last Post: 17th Jan 2008, 02:36 -
adobe permiere 2
By forare in forum Off topicReplies: 7Last Post: 2nd Oct 2007, 15:11
