Many of the newer DVD burners coming out now tout being able to burn at 16X for single layer and 8X for dual layer. However I have not yet seen any media which claims to handle these speeds. Have I missed something?
Results 1 to 12 of 12
high speed media is available from many retailers,maybe you just need to look harder.
check out the media section to the left,or try online,depending on which country you live in.LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
My local walmart has 16x SL DVD media. What I'm waiting for is 8x DL DVD media to be sold locally. I can only find 2.4x and 4x media at present. I've been told it should be here by the holidays.
I had only been looking for it over at "tiger direct". gues they are a little behind. Still no 8X DL though I guess.
Tiger direct can be rather pricey for media. You may want to check meritline.com or supermediastore.com
Yes, I just did. And did find 16X media for a good price. think I'll do my shopping there!
What about these? BeAll 16X Media
http://www.cdrdvdrmedia.com/beall-16x-dvd-r-media.html
http://www.cdrdvdrmedia.com/beall-16x-dvd-r-media-dvdr-blank-media-printable.html -
Burners have always had speeds higher than media available.
The only time I can think of an exception was 3 companies (PVC, MCC, TDK) had 2x media when the first burner appeared in 2001. But everybody else was 1x for quite a while (at least a year)..Want my help? Ask here! (not via PM!)
BeAll media is crap.Originally Posted by scoooott
Find some Verbatim media locally in stores (Best Buy):
MCC03RG20 is 16x DVD-R
MCC004 is 16x DVD+R
Or buy from an online store like supermediastore, meritline or rima:
TYG03 is 16x DVD-R
Plenty of 16x DVD around, just look.Want my help? Ask here! (not via PM!)
I found a verbatim DVDs, but I don't know media code.
$27.5 for 100 pcs
www.cdrdvdrmedia.com/verbatim-16x-dvd-r-media-branded.html -
It will be MCC
Will media ever go beyond 16X?
By videobread in forum MediaReplies: 7Last Post: 22nd Aug 2008, 13:16 -
Phillips DVD+R, 16x, media code: CMC MAG. M01...These any good?
By i am x in forum Newbie / General discussionsReplies: 1Last Post: 15th Mar 2008, 11:26 -
Starlogic 16x R+ Media
By joefromflorida in forum MediaReplies: 3Last Post: 31st Jan 2008, 22:17 -
Taiyo Yuden 16X Water Shield White Inkjet Hub Printable DVD-R Media
By mn072065 in forum MediaReplies: 66Last Post: 28th Sep 2007, 11:29 -
I/O Magic DVD ReWritable 16X Drive Not running at 16X
By mmitsch in forum DVD & Blu-ray WritersReplies: 3Last Post: 7th Jul 2007, 00:40
