  1. Hey,
    I add subtitles to a DVD using this guide:
    https://www.videohelp.com/forum/viewtopic.php?t=219535
    and after finishing with DVD-Lab I went to update the IFO with IFOUpdate.
    but then I got an error saying: "The original IFO's PGC area is not large enough to hold the new PGC"
    after a littel search on the web I understood that the error has to do with the chapters. so I edited the orginial IFO (VTS_01) with IFOEdit and I saw this:
    also in DVD-Lab pro after importing the m2v file, in the time line it says: 0-GOP. and after inserting it it's 00:00:00 across the whole time line:
    I have done many movies with that guide and this is the first time I get this error, so theres nothing wrong with my setting or something.
    I understood it is possible to do so also with VobBlanker, but i'm not so sure how.
    anyone have an idea ?
  2. Hi.
    You need to rewrite the GOP Timecode. Select the video into asset e choose "rewrite GOP Timecode" and click in "full process". after that delete the video from assets window and import again. Check if there is time now.
    8)
