Hi, i need help please!
How can i make change a menu to another menu by only moving on right button on remote dvd ( without click on enter )?
Thanks!
If your menu does not have buttons on it and you don't need the up, down, left, and right buttons to navigate and you absolutely must have the next button call the other menu:
In the connections window, right click on the menu you want this to work on> select "UOP & settings"> in the dropdown box next to "Next button" select "Follow end link to next Menu"> hit ok. Then draw a line between this menu and the next menu you want it to go to.
If your menu does have buttons on it and you do need the arrow buttons to navigate, make a button on your menu and link it to the next menu. Then in menu properties checkmark the tickbox next to Auto Action for this button. This will both highlight and press the button once you navigate to it so you don't have to hit enter.
DVD-Lab pro menu problem
By wackman in forum Authoring (DVD)Replies: 4Last Post: 26th Aug 2008, 04:52 -
Subtitles problem in DVD-lab pro
By spyart in forum Authoring (DVD)Replies: 1Last Post: 25th Aug 2008, 15:14 -
DVD Lab Pro compilation problem
By JohnCPun in forum Authoring (DVD)Replies: 11Last Post: 8th Jan 2008, 16:31 -
Problem with DVD LAb Pro...
By GangstaRap in forum Authoring (DVD)Replies: 19Last Post: 20th Dec 2007, 13:23 -
DVD-lab pro compile problem
By Sats in forum Authoring (DVD)Replies: 8Last Post: 11th Sep 2007, 15:13
