all,
when i use TMPGEnc Author, i can just about cut adverts out but sometimes i cannot get the exact frame i want to cut. something to do with I & P frames?
when i use TMPGEnc Express, i have greater control about the exact frames i want to cut.
however, generating a new cut down mpg file using TMPGEnc Express can take ages.
example, a 1 hour show. cut out adverts. don't do anything else as far as i can see. generate new mpg file takes over 2 or 3 hours!
my original mpg file is pal, 704x576, 4:3 aspect ratio and as far as i can see, TMPGEnc Express outputs the exact same mpg format bar the adverts.
TMPGEnc Author, on the other hand, takes a few minutes to do the same task.
what am i doing wrong? is there some trick i'm missing?
any help would be appreciated people.
my spec: windows xp (sp1), amd athlon 1.8GHz cpu, 80 GB hard drive, ati aiw 9800 grap card, soundblaster audigy 2.
oops, should have asked if any other apps does the job better & faster than TMPGEnc Express. there i've asked it!
Check it's not set up to do mpeg1 input and then mpeg2 output? i.e Xpress is then encoding it also, hence the time! Xpress is slow but shouldn't take that long.
Alternative freeware:
1. Demux (projectx, pvastrumento...)
2. Cut with cuttermaran (will use tmpgenc only for cut GOPs => very fast)
Use the elementary streams in TDA
Advantage: 100% sync streams (with proper 'starting material')...GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
The reason TMPGEnc Express takes so long is that it's an encoder. No matter what you do to the file, it encodes the whole file again. A video editor will only have to re-encode the edited parts. So any of the programs mentioned above will work. TMPGEnc Mpeg Editor is another one that would do the job.
TmpgEnc Express can't open some AVI
By pcb in forum Video ConversionReplies: 7Last Post: 29th Jul 2011, 14:28 -
Medieval helpdesk. What tech support was like in the middle ages.
By freebird73717 in forum Off topicReplies: 2Last Post: 5th Jul 2009, 00:05 -
ADS DVD Express DX2 No video capture
By jimbob56nc in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jun 2009, 10:25 -
lost audio after capture on ads tech dvd express dx2
By allan4371 in forum Newbie / General discussionsReplies: 1Last Post: 17th May 2009, 22:03 -
SVCD2DVD taking AGES to convert files.
By smileymyley in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 22nd Jun 2007, 15:53
