What is the general consensus on Chapters?
For an episode of show X, there are opening credits (i dont cut these I know many of you do tho), the halfway point, and then the end credits. So chapters at the 3 points can be quite annoying finding all of these as rarely are they the same time.
So the other alt is chapters every X mins.
I use option 1 mainly, but its starting to become a hassle, I spend a good 30mins to an hour determining chapter points for 20+ episodes.
for episodes, i make a chapter point at the begining of the show or opening credits, unless its longer than 30mins i wont add any more chapters for the episode, for everything else i add them according to where i think a scene has ended. hth
For TV shows, I always place chapter points in between each segment (where the show dips to and from black for commercial breaks). I ususally end up with anywhere between 5-7 chapter points in an episode.
For TV shows, I set a chapter point at the start of the opening credits, one at each commercial break, and one at the start of the closing credits. If there's a "previously on" segment prior to the opening teaser (before the opening credits) then I set one at the start of the teaser too.
Buy My Books
Editing subtitle on diferent positions
By Capum in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2010, 09:59 -
How to switch DVD audio channel positions?
By coxanhvn in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2010, 12:29 -
Overlay text at various positions via avisynth subtitle() function ?
By vhelp in forum EditingReplies: 3Last Post: 11th Jul 2009, 03:29 -
Adding graphic subtitles to Divx with correct sizes/positions?
By picrade in forum SubtitleReplies: 1Last Post: 1st Apr 2008, 03:13 -
Default highlighted menu button positions
By ToddS in forum Authoring (DVD)Replies: 3Last Post: 22nd May 2007, 00:24
