Everytime I load "Media Center", I get the message...
"There is no disk in the drive. Please insert disk in drive"
When I try to close it, it simply pops up again. How do I stop this from happening other than keeping a disc in the DVD-ROM drive. In addition to the DVD-ROM drive I also have a DVD writer.
A solution to this problem would be appreciated. Help!
Haven't seen that one pop up ever but I bet you can find an answer on the forums over at www.thegreenbutton.com
FB-DIMM are the real cause of global warming -
Thanks rallynavvie, I'll have to check out that forum tonight. If anybody here knows of a solution, please reply, in case I'm unable to get the answers elsewhere. Thanks.
I'm guessing you have an HP branded Media Center? Does it have an application on it called "HP Image Zone"? Apparently that causes issues with the USB media card readers that are built-in. Disable the card readers and remove HP Image Zone, then re-enable the card readers and see if that works.
Yes I do have an HP branded Media Center. I actually found out what was causing MC to access my DVD-ROM a few minutes ago while going through MCE's settings. In "More Program Options", under settings, I unchecked "Control the media experience in Media Center". This has solved my problem. I don't know how I had missed this. Anyways, thanks again for your help.
"Front left of center (FLC)" = ?
By Asterra in forum AudioReplies: 2Last Post: 20th Apr 2012, 21:14 -
any good "my movies" plugins for Windows media Center?
By craig198 in forum Media Center PC / MediaCentersReplies: 0Last Post: 26th Jan 2011, 13:47 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
Anyone using Windows XP Media Center Edition? Thanks for help.
By seymoria in forum Capturing and VCRReplies: 2Last Post: 27th Dec 2008, 22:27 -
Windows Media Center can't burn its own files? (Vista Premium edition)
By yoda313 in forum Media Center PC / MediaCentersReplies: 5Last Post: 7th Apr 2008, 15:44
