I recently have been experiencing problems by not being able to burn any video to cd-r .
In the past I was able to burn vcd's no problem. Yet in past week, I have been getting increasingly poor quality burns a lot of skipping and now its to the point where discs can't be read at all.
-defragged the hard drive
-used proper burning software, Roxio
-burned at a lower speed
-tried different brands of cd-r
-switched to CD-RW instead of CD-R
Recently,
-used disc cleaner
-tried switching to a different burning program , Nero
using dell laptop, inspiron 5150:
drive model#: QSI CDRW/DVD SBW-242
I would say it's your writer,buy an external or see if the laptop is still under warranty.
see the funny thing is that I can burn a bunch of word or excel files to one disc and it burns perfectly. The only problem is video . . .
btw, I also did a virus check one with my anti-virus program, F-secure and one online, panda active-sccan and nothing showed up.
Another thing is I used to burn video using the "send to" feature in windows explorer and that no longer works, for video. Instead I have use to use a burning program, where as before I never needed to. -
Roxio and Nero don't play nice together,uninstall Roxio.Make sure to uninstall Roxio's packet writing software too.
see the thing is that I can burn word files and excel files no problem using the either program . . . so is the software conflict you are referring to . .only effected by burning video files?
thanks guys
I was sucessful in that Dell finally conceeded that the drive was dead.
I replaced it finally, now working like it was supposed to.
Burner can only burn to Verbatim Media, but not anymore...
By iownju in forum MediaReplies: 6Last Post: 19th May 2010, 06:53 -
Nero 9.2.5.0 - Can't burn anymore (error message enclosed)
By rock_king_my in forum Newbie / General discussionsReplies: 9Last Post: 14th Apr 2009, 11:02 -
No mp3 sound anymore
By wayne36 in forum ffmpegX general discussionReplies: 3Last Post: 26th Jul 2008, 13:15 -
virtualdubmod not running anymore!!
By pskim in forum Video ConversionReplies: 3Last Post: 9th Feb 2008, 21:39 -
I can't see videos anymore!
By cece0808 in forum Newbie / General discussionsReplies: 1Last Post: 18th Aug 2007, 19:46
