Hi Guys,
Can anybody please tell me the difference (changes) between the two versions of Adobe Premier Pro 7 and Premier Pro 1.5.
Bye
Premjit
encore is the dvd authoring program. Premjit means the difference between Premiere 7 and Premiere Pro 1.5.
You can do a google search for "premiere pro review" and find countless sites listing the changes.
Basically:
no more A/B editing
nested timelines
more stable
drag and drop editing
new interface
here's some more in depth reviews:
http://www.creativecow.net/articles/velte_mike/premiere-pro/
http://desktopvideo.about.com/od/gttheadobestudio/fr/premiere15full.htm -
Actually, there was a considerable jump from 6.5 to Premiere Pro (ver7)..
Premiere Pro 1.5 is an enhanced version of Premiere Pro (ver7)..
It allows for more functions borrowed from Adobe After Effects...
As far as using it for NLE purposes, both Premiere programs should do you justice.
If you're looking for eye candy, then don't even bother..Use a dedicated program like After Effects..
Good luck!!! -
The original line of Premiere ended with version 6.5. Premiere Pro 1.0 (aka Premiere 7) was a total rewrite. The new version was written for Windows XP (DirectX) only. Mac was dropped. Premiere Pro 1.5 is the latest version in the new series.
Differences for version 1.5 are listed on the Adobe site.
http://www.adobe.com/products/premiere/newfeatures.htmlRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Importing VOBs in Adobe PremierPro CS5
By LiaP in forum Newbie / General discussionsReplies: 1Last Post: 16th Nov 2010, 15:55
