Help........I have no luck to converted a DVD movie from friend send me oversea. It is compress in MPEG-2, picture in interlaced Pal DVD. I did try dvdSanta and it does it but the resolution is poor. Please, some one help me to keep the original resolution with NTSC system................................Thx.
PAL to NTSC is not simple if you want good quality. I would try VSO DivxToDVD. It does a better job than 'Santa'. There is still a freeware version available.
If that doesn't do it, study the guides. <<<<<<
https://www.videohelp.com/convert#4;41 -
You can buy a region free DVD player that does PAL to NTSC conversion for ~$35. The results won't be perfect but watchable.
I've been using ulead video studio 7 and 8 se's to do this type of conversion , so far , no problem's , pick them up in ebay for $35.00 au .
You also get alot of bonus features in the package , so it's worth while in the long run , and relatively cheap .
PAL converted from NTSC source - Ghosting and interlacing
By OngekibouRekka in forum Video ConversionReplies: 7Last Post: 3rd Dec 2011, 13:20 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
random subtitles missing after remuxing converted PAL-to-Ntsc
By spiritgumm in forum SubtitleReplies: 5Last Post: 19th Jan 2009, 12:56 -
Fix ghost effect in a bad ntsc to pal converted original DVD
By Talayero in forum Video ConversionReplies: 8Last Post: 16th Jul 2007, 06:40 -
29.976 to 25fps (removing pulldown from a NTSC converted PAL film transfer)
By ecc in forum Video ConversionReplies: 25Last Post: 15th Jul 2007, 23:31
Thanks, I will try it then.
