I have a wedding video which I want to dub certain boring sections with music. Is it possible with Tsunami Dvd author pro?
I read the box and it says:
"For consumer DVD authoring software within its price range, DVD AUTHOR PRO is the first software package that supports high quality 24bit/96KHz (2 ch)* linear PCM input and output, and it is now also possible to add two simultaneous audio streams per video track. DVD AUTHOR PRO also supports Input and output of Dolby Digital® audio streams. * The highest possible sound quality within the DVD-Video standard. "
So I thought it might be possible but wanted to verify before I made the purchase. Thanks
If you want to actually change the original soundtrack by replacing only parts of it with music then TDA isn't the software for you. To do that you will need an audio editor. Extract the audio from the original DVD (a process called demultiplexing, or demuxing) then load it into your audio editor (note: if the audio was AC3, you may have to convert it to wav first). Dub over the original dialogue and audio with music in the required places, then save the new sound track.
What you do now depends on what the source audio was. You may have to convert your new audio to AC3. You may be able to just mux the new audio straight back in.
If you are happy to create new menus, then just grab the video from the original, the new audio, and use TDA to create a new DVD. You could even keep the original audio as well, as you can have two audio tracks.Read my blog here.
Well I believe tda also accepts .mp2 audio. I know it does from my mpeg recordings off of my wintv pvr 250 which uses mpeg audio instead of ac3.Originally Posted by guns1inger
Just fyi if the original poster doesn't have a ac3 encoder handy.
How to full backup (no encoding) BR main movie, main audio with subtitles ?
By meico1234 in forum Blu-ray RippingReplies: 2Last Post: 2nd Feb 2009, 04:37 -
Adding audio as background music whilst listening to the main sound
By Mrwoo1234 in forum AudioReplies: 3Last Post: 29th Dec 2007, 10:30 -
Adding an Audio/Music Clip into the main Audio Track?
By Moontrash in forum EditingReplies: 3Last Post: 20th Nov 2007, 18:45 -
Tsunami-Mpeg DVD Author Pro Transcoder Question
By RKelly in forum Authoring (DVD)Replies: 6Last Post: 16th Aug 2007, 22:51 -
main menu music, nerovision express 3
By Reggie6966 in forum Authoring (DVD)Replies: 4Last Post: 10th Jun 2007, 08:00
