How do I add black outline in DVD-Lab pro to my subtitles? I'm using Tahamoa yellow font with Thick and Fat outlines but it shows white outline instead of black.
I have no idea. Outlines for me are black by default and no matter what I do I can't change them. If you're really persistent about this, try asking here: http://www.mmbforums.com/phpbb/index.php?
EDIT: Try doing a search on "subtitles AND color AND outline". Some very informative threads there and your solution would depend on your method of generating subs. -
Thanks for the reply shadow. I'll do both that. BTW, mine is black by default too during the setup/prep process but after the compilations is done and everything is finally authored i play the dvd and the color ends up gray or white, not black.
I fixed it. I went to project properties to change the color pallete. The "black" color was 51 51 51 not 0 0 0. That's why.
Glad it worked out for you. Thanks for posting your solution.
[DVD Lab Pro] subtitles wrong time
By dom61 in forum Authoring (DVD)Replies: 2Last Post: 4th Sep 2011, 07:42 -
DVD-Lab Pro Subtitles Encoding troubles
By laste in forum Authoring (DVD)Replies: 1Last Post: 16th Jan 2011, 14:12 -
Subtitles problem in DVD-lab pro
By spyart in forum Authoring (DVD)Replies: 1Last Post: 25th Aug 2008, 15:14 -
Add a menu to a DVD without re-authoring, using DVD-Lab Pro
By petar in forum User guidesReplies: 38Last Post: 12th Mar 2008, 12:22 -
out of sync subtitles - DVD Lab Pro
By GangstaRap in forum Authoring (DVD)Replies: 2Last Post: 12th May 2007, 15:57
