    Mar 2003
    Singapore
    help! how to add logo into my mpg file?
    I cant find any prog to add in a logo..
    No a standard vcd mpg file is a very small custom mpg file . thx
    CPU Speed: AMD Athlon(tm) 64 Processor 3200+ 2.0 GHz
    RAM Memory: 1024 MB (28% Utilized)
    Video Card: 1280 x 1024 in 32-Bit Color, RADEON X800 PRO Ver.
    Capture Card: Pinnacle WDM PCTV Video
    USA
    You should have checked the FAQ's to the left. <<<<<<<
    https://www.videohelp.com/faq#logoadd
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    There's even a guide:
    https://www.videohelp.com/guides.php?guideid=714#714
    If in doubt, Google it.
