I have some video that has big waves in it, like if you were looking at a fun house mirror, and some other video that does a small, quick, and jumpy wave every few seconds. What causes this? Can either problem be fixed at all? The tapes are copies of the original tapes that had the wavy problem.
Dorian
I tried using Deshaker on the video with the quick jumpy waves and it did reduce the problem, but the video and audio keep randomly pausing. It's kind of like it's being played in slow motion in parts. I used the settings for Deshaker from this tutorial http://www.sundancemediagroup.com/articles/deshaker_guide.htm.
Anyone know why this is happening?
Dorian -
A TBC may fix something like that, someone else may be able to give you a better idea especially if you post an example clip or screenshot.
My guess is that your going to be out of luck though if they are second generation because the error is no longer a error but part of the content.Originally Posted by Dorian -
Here's an example of the video I'm trying to fix. This is without trying to use Deshaker.
http://www.philipearl.com/clip.mpg
Dorian -
I think Deshaker might help. I had the same problem with it when I tried it, getting pauses. I figured out I probably had the wrong settings and gave up. You may have to isolate the shaking frames as much as possible and play with the settings a bit more. It doesn't look like there is a blur during the shake, so it should be fixable, with enough time invested.
Womble MPEG Video Wizard DVD is re-encoding video, claiming not to (FIXED)
By Brad in forum Authoring (DVD)Replies: 11Last Post: 2nd Mar 2012, 21:28 -
Capturing in MPEG Gives Wavy Video
By MasterOfPuppets in forum Capturing and VCRReplies: 18Last Post: 7th Jul 2010, 08:22 -
Running video behind fixed image.
By D138 in forum Newbie / General discussionsReplies: 11Last Post: 16th Mar 2010, 15:32 -
Wavy video
By steebee in forum RestorationReplies: 20Last Post: 31st Jul 2009, 00:56 -
Crazy, wavy black lines on capturing from jerky video (images&vids in p
By osteopants in forum Capturing and VCRReplies: 4Last Post: 11th Jan 2008, 12:25
