Statistically, what's the best Anti Virus out there?
APART from Norton!!
Results 1 to 30 of 36
That's sorta been thrashed around here: https://www.videohelp.com/forum/viewtopic.php?t=284533
Why not make it a poll if you want to get a statistical number of how many use each of the more popular ones.
BTW, AVG mostly. -
I use AVG on all my systems.
http://free.grisoft.com/doc/1You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Free versions of AVG on all my computers and AVAST. I no longer use NORTONS SYSTEMWORKS w/ANTIVIRUS because it's a resource hog. Although I do install the NORTONS UTILITES to use the SPEED DISK & WINDOCTOR.
Originally Posted by SE14man
AVG free on both machines here (one is windows server 2003 enterprise and it hasnt given me any issues strangely enough. Ive been told elsewhere that AVG free doesnt work on a server OS
). been great.
Best A/V? NOD32 get very good reviews..When i swithched from Norton..i installed and ran it, it found stuff Norton didn't.
I use ZoneAlarm Security Suite..I believe the A/V part uses the Kapersky engine. Been fine, with the top firewall too..not had any problems. Supposedly-as with NOD32- it less drain on processor too.
Neither are free...but can be aquiredThe laziest man I ever met put popcorn in his pancakes so they would turn over by themselves!! -
AVG for me, and its free!
If at first you don't succeed; call it version 1.0 -
Another vote for AVG from me. Never had a problem with it, but occasionally run McAfee Stinger as backup.
we are making the statistics
Well, AVG caught some things my old Norton had missed. So I'm pretty pleased with AVG right now, just switch last week.
Originally Posted by FlaystusThe laziest man I ever met put popcorn in his pancakes so they would turn over by themselves!!
I use AVG now, I have used Avast in the past and I really like both of them, they are both excellent!
Originally Posted by aweegin
Good antivirus info site: http://www.virusbtn.com/index -
Originally Posted by Faustus
I remember Kaspersky being consistently in the top couple in several tests - IIRC, better over time than anyone else, but don't quote me. But that one looks like a contender if you're willing to pay. I'm no sycophant - I've never bought or installed it - just reporting my memory.
Google AV comparisons and check 'em out yourself. -
Statistically, how many times has this question been asked?
McAffee and AVG. -
Yet another thread about best antivirus. Come on. Haven't got anything better to do????????
Just curious. Did any of the Anti-virus program pick up the Sony Rootkit virsus before all this broke a couple of weeks ago?
AV apps do not detect rootkits (yet). i only know of one that will remove them and three that will only help to detect them. As they become more "popular" av will start to detect/remove them in the future, much like av is now starting to detect/remove malware, although its still best to have both av and malware apps
Firewall should catch rootkits.
firewalls wont catch rootkits. rootkits can hide from and manipulate window components. even some trojans and viruses can bypass firewalls.
I was using norton for quite a long time. I had just upgraded to NAV 2005 in July. Ever since, it was giving me problems. It didn't always load the auto-protect; it would not load auto-protect when I would try to manually turn it on and it wouldn't even let me activate it. I switched to AVG Free. It works great. I have replaced NAV on all my systems with Grisoft.
Melde Melda Vessë
Eruanna ar Eruntano Melda Eruntanohini
"May your days be bright and contact with stupid people limited." -
Avast is one of the best, works good for me. It doesn;t take as many resources as norton
Originally Posted by isogonicWant my help? Ask here! (not via PM!)
not sure what "auto-load software" is but rootkits can run at the kernel level and can not easily be detected by current detection/monitering tools including a firewall. hacker defender came out a year ago and it could use a common tcp port. they are getting much more sophisticated these days.
anti-virus
By Willy5157 in forum ComputerReplies: 19Last Post: 14th Dec 2011, 09:13 -
Do you use Norton anti-virus or freeware of something else?
By beavereater in forum ComputerReplies: 26Last Post: 31st Jan 2011, 22:34 -
Free Anti-Virus Opinions
By HotDamn! in forum ComputerReplies: 19Last Post: 13th Jan 2010, 15:49 -
AVG Anti-Virus & Anti-Spyware V8.0 1User/2Year Small Box - Retail
By MJA in forum Off topicReplies: 3Last Post: 13th May 2009, 21:28 -
Norton Anti-Virus: I Think I Have Been Shafted
By Tom Saurus in forum ComputerReplies: 27Last Post: 21st May 2008, 18:11
