Hello i have been using nero for a while now and using winavi video converter to convert to dvd format but a friend can just add the avi straight to nero then burn.
I have no idea why i cannopt do his can any body shed any light on it it just says unable to import avi when i try.
Tim
He may well have a different version of Nero - one that includes NeroVision Express, by any chance ?
Either way, IMHO you're asking for trouble using WinAVI OR Nero as encoders, but ....... your choice I guess.If in doubt, Google it. -
would it not also depend on what codec the avi uses to play? (struggling for technical words here
What you recommend to use for converting avi and mpegs to dvd and burning them to dvd?
And regarding codecs my computer plays then all fine and i have installed all the codecs relating to the problem but still no joy
Tim -
As far as the one-click-wonders go, I like DivXToDVD. Most of the time though, I do it the manual way using TMPGEnc Plus. http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm outlines the method I use.
Nero burning 'Communication Failure'
By geo g in forum Newbie / General discussionsReplies: 3Last Post: 19th Apr 2010, 17:32 -
Converting AVI to WMV failure
By Buu in forum Video ConversionReplies: 4Last Post: 8th Feb 2010, 16:04 -
Burn Failure (Nero 7)
By TunkaFrankie in forum DVD & Blu-ray WritersReplies: 26Last Post: 11th Sep 2008, 23:35 -
Internal Target Failure on Nero
By ChonasMan in forum Authoring (VCD/SVCD)Replies: 12Last Post: 10th Aug 2008, 20:45 -
nero - dvd burn failure - no seek complete error
By rock in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2007, 15:28
