I used this guide,
www.vcdhelp.com/pinoy2201sdvdrippinguide.htm to rip a dvd. I got all the way down to "5th Step Encoding All Of It To A VCD Mpeg file" The problem is that when I load the template TMPG says Illegal Stream Format. Can anyone tell me what I am doing wrong?
Do you mean;
when you load the TMPGEnc template? Or do you mean something completely else with template?
The Dutchman -
I get to step 5.
It says:
Now open TMPGEnc and load my template select ntsc for region 1 and 2 and pal for 4 and 5:
I downloaded his templates and tried to open them in TMPGEnc
from the file, open window and an error comes up "Illegal Stream Format" -
Make sure you've got DVD2AVI.vfp in the same directory as Tmpenc, that could be the trouble.
Did you store the template in the TMPGEnc folder?(under templates)
The Dutchman -
I put the templates in the TMPGEnc template folder.
I tried doing it with TMPGEnc in the same folder as DVD2AVI
I get the same error on both of them still. Is there any other way to get around this. Maybe different software? -
Did you move tmpgenc to the dvd2avi folder? (bad), try moving everyting in the dvd2avi folder to the tmpenc folder
_________________
If i can help, I will... ICQ 141601820
<font size=-1>[ This Message was edited by: mh2360 on 2001-12-27 06:42:49 ]</font>
no audio on playback tmpg
By devdev in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2011, 13:05 -
jerky tmpg
By devdev in forum Authoring (DVD)Replies: 6Last Post: 12th Aug 2010, 09:14 -
TMPG DVD Author-old version
By Mållgan in forum Authoring (DVD)Replies: 12Last Post: 7th Mar 2010, 17:46 -
TMPG plus vs. free version
By bellyting in forum Newbie / General discussionsReplies: 2Last Post: 4th Jul 2007, 02:11 -
DVD authoring and encoding on TMPG and Ulead
By bellyting in forum Newbie / General discussionsReplies: 4Last Post: 29th Jun 2007, 17:53
