Hello i am new to this forum but i have a problem with my dvd writer as it wont burn to dvd-r disc either data or video but works fine on dvd+r i have got a log from a failed burn from Nero 6.6.0.18. i have nero and dvdshrink and ulead dvd movie factory installed but just fails everytime i burn.
Please help me.
Tim
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 18:35:34
Nero Version: 6.6.0.18
Internal Version: 6, 6, 0, 18e
(Nero Express)
Recorder: <TSSTcorp CD/DVDW TS-H552B>Version: TS04 - HA 1 TA 0 - 6.6.0.18
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <AXV CD/DVD-ROM >Version: 2.2a - HA 4 TA 0 - 6.6.0.18
Adapter driver: <a347scsi> HA 4
=== Scsi-Device-Map ===
CdRomPeripheral : SAMSUNG CD-R/RW SW-252S atapi Port 0 ID 0 DMA: On
CdRomPeripheral : TSSTcorp CD/DVDW TS-H552B atapi Port 1 ID 0 DMA: On
DiskPeripheral : VIA SATA RAID 0 viasraid Port 2 ID 0 DMA: Off
OtherPeripheral : Promise RAID Console 1.00 fasttx2k Port 3 ID 4 DMA: Off
CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 4 ID 0 DMA: Off
CdRomPeripheral : SCSIVAX DVD/CD-ROM 2.7a Vax347s Port 5 ID 0 DMA: Off
=== CDRom-Device-Map ===
SAMSUNG CD-R/RW SW-252S F: CDRom0
TSSTcorp CD/DVDW TS-H552B G: CDRom1
AXV CD/DVD-ROM E: CDRom2
SCSIVAX DVD/CD-ROM H: CDRom3
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1022MB (1047280kB)
Free physical memory: 320MB (328588kB)
Memory in use : 68 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
19.11.2005
ISO compilation
19:49:29 #1 Text 0 File Isodoc.cpp, Line 6359
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
19:49:29 #2 Text 0 File Reader.cpp, Line 127
Reader running
19:49:29 #3 Text 0 File Writer.cpp, Line 122
Writer TSSTcorp CD/DVDW TS-H552B running
19:49:29 #4 ISO9660GEN -11 File geniso.cpp, Line 3309
First writeable address = 0 (0x00000000)
19:49:29 #5 Text 0 File Burncd.cpp, Line 3233
Turn on Disc-At-Once, using DVD media
19:49:29 #6 Text 0 File DlgWaitCD.cpp, Line 270
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 62543 ( 13:53.68, 122MB)
19:49:29 #7 Text 0 File DlgWaitCD.cpp, Line 282
Write in overburning mode: NO (enabled: CD)
19:49:29 #8 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: TSSTcorp CD/DVDW TS-H552B, Media type: DVD-R
Disc Manufacturer: TTG02 -
Disc Application Code: 64, Disc Physical Code: 193
19:49:29 #9 Text 0 File DlgWaitCD.cpp, Line 448
>>> Protocol of DlgWaitCD activities: <<<
19:49:29 #10 Text 0 File ThreadedTransferInterface.cpp, Line 838
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 62544 (62544) = #62544/13:53.69
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 62544 blocks [TSSTcorp CD/DVDW TS-H552B]
19:49:34 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [TSSTcorp CD/DVDW TS-H552B] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 128090112, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
62544 | lead-out | 1 | 0x41 | 0x00
19:49:34 #12 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
19:49:35 #13 Text 0 File Burncd.cpp, Line 4122
Cache writing successful.
19:49:35 #14 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
19:49:35 #15 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 8x (11,080 KB/s)
19:49:40 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2661
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
19:49:40 #17 Text 0 File DVDR.cpp, Line 2571
Recording mode: Sequential Recording Mode for Multisession
19:49:40 #18 Text 0 File Mmc.cpp, Line 21774
Set BUFE: Super Link -> ON
19:49:40 #19 Text 0 File DVDR.cpp, Line 2726
Start write address at LBA 0
DVD high compatibility mode: Yes
19:49:40 #20 Text 0 File Cdrdrv.cpp, Line 8892
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
19:49:53 #21 Text 0 File Cdrdrv.cpp, Line 1288
19:49:53.000 - TSSTcorp CD/DVDW TS-H552B\H1 T0 : Queue again later
19:49:59 #22 SCSI -1135 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x082A0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x03 0xC0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
19:49:59 #23 CDR -1135 File Writer.cpp, Line 311
Write error
19:49:59 #24 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
19:49:59 #25 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
19:49:59 #26 Text 0 File DVDR.cpp, Line 2969
EndDAO: Last written address was 959
19:49:59 #27 Phase 133 File dlgbrnst.cpp, Line 1832
Writing short lead-out
19:50:03 #28 SCSI -1176 File Cdrdrv.cpp, Line 1182
Sense Code: 0x72
Sense Qual: 0x00
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x72 0x00
19:52:23 #29 CDR -1176 File WriterStatus.cpp, Line 167
Session fixation error
19:52:23 #30 TRANSFER -24 File WriterStatus.cpp, Line 167
Could not perform end of Disc-at-once
19:52:23 #31 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 8x (11,080 KB/s)
Existing drivers:
File 'Drivers\atapi.sys': Ver=?.?.?.?, size=95360 bytes, created 04/08/2004 12:00:00 (Adapter driver for rec)
File 'Drivers\a347scsi.sys': Ver=3.47.0.0 built by: WinDDK, size=5248 bytes, created 30/04/2004 09:33:00 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Either your burner doesn't like DVD -r or the brand of DVD -r you are using would be my guess. Try a different brand. You could check to see if there is upgraded firmware for you burner also.
Why not stick with DVD +r if it works for you? -
Hello,
I have checked firmware and updated it but thats didn't help me but i will try another brand tha i have to see if that works.
I would use dvd+r all the time but all the dvd players around me work better with DVD-R
Tim -
There's a review of that DVD burner here: http://www.cdrinfo.com/Sections/Reviews/Specific.aspx?ArticleId=11318
If you go forward a few pages, there is a list of suggested DVD media to use. I didn't see the one you are using listed. That may be part of the problem.
I also see some similar problems to yours when doing a Google search for that model. -
I think the issue came from XP.
I have been using identical material and drive ( external USB burner ), and windows 2000 don't have any issue with DVD-R. But XP won't burn DVD-R with nero.
I wonder nero 7 is any help ?
Nero burning 'Communication Failure'
By geo g in forum Newbie / General discussionsReplies: 3Last Post: 19th Apr 2010, 16:32 -
Burn Failure (Nero 7)
By TunkaFrankie in forum DVD & Blu-ray WritersReplies: 26Last Post: 11th Sep 2008, 22:35 -
Internal Target Failure on Nero
By ChonasMan in forum Authoring (VCD/SVCD)Replies: 12Last Post: 10th Aug 2008, 19:45 -
question about repeated DVD burn failure at about 90%
By jimdagys in forum Newbie / General discussionsReplies: 18Last Post: 18th Mar 2008, 21:34 -
nero - dvd burn failure - no seek complete error
By rock in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2007, 14:28
