Is there another program that will do what dvd shrink does, but more consistently? in backing up my collection, I notice that dvd shrink will not backup alot of my dvds, new or old. Thanks for any advice![]()
I would only add to the above reponses, that DVDShrink (used properly) should not have any problems with "older" titles. A few of those released in 2005 do have newer forms of copy protection that can cause DVDShrink to choke, and these few discs can stump it. However, Most of those are easy to identify, just by searching this forum (most have been Sony titles, or Columbia or Tristar titles, and only the ones released after December of 2004). All "older" titles should not cause DVDShrink any problems.Originally Posted by Noek
So, it may be important to ask if there is some other cause for many of your failures. Perhaps a "bad original disc," in that it is in need of some cleaning, or it has gotten fingersmudged, scratched, or somehow marred? Or, is there something in your system setup which is making things "hit or miss"? DRM versus PIO problems, or lack of memory, or a conflicting driver (Roxio has one that sometimes conflicts with Nero, a popular burning tool for use with DVDShrink)?
If you are having problems with older discs, it is very likely that switching to a different ripper is not going to magically solve the issues. You are very likely to find that any other similar ripper or compression software still fails to function, for the exact same reason. I would suggest that you try to get to the root of the problem, instead.
Just my thoughts,
-Bruce
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
Alternate download locations
By teamsleep in forum ffmpegX general discussionReplies: 7Last Post: 22nd Apr 2012, 05:24 -
By MGadAllah in forum LinuxReplies: 1Last Post: 6th Nov 2011, 02:17 -
Free AMCAP Alternate?
By Mickz in forum Capturing and VCRReplies: 8Last Post: 4th Aug 2011, 21:13 -
Alternate format other than DV.
By cowmix in forum Capturing and VCRReplies: 13Last Post: 14th Sep 2009, 23:21
