    Nov 2005
    Czech Republic
    I have tried to frame server from Virtual Dub to Main Concept's MPEG encoder. Everything seems to be fine but the video is just solid green. Anyone have any suggestions? I have no clue.
    Thanks.
  2. In Options / Import Modules, try to disable some modules and try so.
    Good luck.
    Nov 2005
    Czech Republic
    Is that in VDub or Main Concept?
  4. Mainconcept.
    Nov 2005
    I had the same problem when I wanted to frameserve a QT file with Avisynth. I had to re-order the modules.
    1. Go to Tools > Import Modules
    2. Select the "DirectShow Import" module
    3. Using the vertical arrows on the left, move it up to the top.
    If it's not working, then reorder the modules and put AVI Import at the top.
    - Dan
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    I'm in the same boat. Actually, tried above reordering and disabling of modules until I turned green, to no avail.
    "Resorted" to frameserving using AviSynth instead, which is as well.
    /Mats
  7. Well, I frameserve using Avisynth. There are many advantages. It's faster than VDub, it's more flexible, you can use templates to save time and it seems to work with MC.
    Try using avisynth tutorials. It's easier than you think.
    Please, tell us if you can frameserve with Vdub, anyway.
