  1. I am currently using the WDM drivers which came with MMC7.1 and I am having capuring problems with XP. I Get audio fine with scrambled video with all inputs. Using iuVCR or virtual dub is fine, looking for a way to get this to work. Would switching drivers to VFW help? and if so where can I get them at?
    Win XP
    celeron 900
    640 MB RAM
    <font size=-1>[ This Message was edited by: mike187 on 2001-12-25 01:17:26 ]</font>
  2. Try MMC 7.2 or 7.5. 7.2 is available from ATI in the XP driver section. 7.5 is availble from Stinky's website (link). Search forums for MMC7.5
    Make sure that you also download the latest display driver from ATI for XP as well. I noticed a noticable performance boost when I put the XP drivers on.
    Other than that, everything else works fine in XP!
    Tjd
  3. OK this is wierd, I still get the scrambled video with the new drivers when I am watching but when I record the capure is normal .How is that explained? I also tryed using the program compatibility wizard and get same results. I have tryed 7.2 nad 7.5 but there is no tv tuner software included with. Also tryed powervcr demos and they work fine. Anybody have a solution for this? a regedit Maybe?
    Jan 2001
    mansoura,egypt
    where i can find mc 7.1 or 7.2 in a site other than ati.. bec this site is verry slow for downloading and it usualy cut bef finishing it.. thanks
