I have a couple mpg2 files, one around 2GB and the other around 7GB that I would like to convert to .vob files. What is a good program to use to accomplish this? I want to burn them onto a DVD. I have Nero and when I select 'Create DVD' it asks for DVD files and looks for .vob files.
I have DVD Shrink installed and it looks for the same types of files as well.
Any help?
Thanks.
TMPGEnc DVD Author is very good for making DVD Video Files.Your MPEG2 files are too large to fit on a single or double layer DVD+\-R though.You will need DVDShrink to transcode the files.Originally Posted by DKRoff~Luke~
I've downloaded TDA and have tried to get the file input, but I get the error message (*The video sequence header is incorrect. The video sequence header is incorrect. A video sequence header is necessary for every GOP in a standard DVD.)
I need this corrected before I can go any further but couldn't find any help on it.
Thanks -
There's a guide in the guides section written by vitualis called "Inserting sequence headers with TMPGEnc" or something similar. It's written for VCD< but all you gotta do is make sure that the system stream type says "MPEG-2 Program (VBR)" instead and it should work.
Either that or MPEG-VCR has a GOP-fixer.If in doubt, Google it.
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
video conversion to mpg2/vob/h264..
By krohm in forum Video ConversionReplies: 14Last Post: 10th Jun 2009, 14:32 -
demuxing mpg2
By volam in forum EditingReplies: 1Last Post: 11th Jul 2008, 14:05 -
Editing Picture Resolution on MPG2 and VOB files
By vivivivi in forum Authoring (DVD)Replies: 1Last Post: 9th Apr 2008, 18:16 -
MPG2 or MPG4???
By JennyBear in forum Newbie / General discussionsReplies: 7Last Post: 1st Aug 2007, 17:33
