Ok, I've read a couple of threads like... DVD+R9 Double Layer first burn: problems with layer switch and Backing up Dual Layer DVDs
but I'm still a little confused...
Usually I back up DL DVD's to +R SL by ripping in FILE MODE with DVD Decrypter, and using Nero Recode to back up. Its SIMPLE, I can walk away, results are watchable, and its worked everytime..
Anyway... As I understand for copying DL to +R DL, the best way is use DVD Decrypter to rip to ISO, then burn ISO to disc using DVD Decrypter which results in a 1 to 1 copy, no re-compression, etc.
But I already have these ripped in FILE MODE... is there anyway to use that to burn to +R DL and make a good copy?
Using recode doesn't work well for me in this case.. for various reasons...
Can I just use Recordnow DLX 7.3, make a "DVD" copy the Video_TS and Audio_TS folders as ripped and sitting on my HD, and burn? Will that work? will the layer break be adjusted if necessary, etc?
Not related to you question, but your avatar is from Yamato, right?
I would guess you could, since you probably ripped the IFO file with the layer break. Never tried it, only used ISOs. If not, re-rip the movies again to an ISO.
Yep.. or Star Blazers as it was called here in the statesOriginally Posted by ofbarea
Yes, using RN7.3 just click on "Data Disc", give it a name (e.g. AVIATOR, THE_HIGH_AND_THE_MIGHTY), drag your AUDIO_TS and VIDEO_TS onto the window, and Burn.Originally Posted by Mark_Venture
I like to have RN verify my burns, and also use Nero CD/DVD Speed to ScanDisc for errors too.
The layer break will work; you may want to use PgcEdit to find it, and then verify it plays OK thru the break on one of your DVD players. -
Cool, that worked!! The first disc I burned, played PERFECTLY...Originally Posted by MaxBlack
Thank you!! -
Yeah, thanks for the suggestion, but now they really have to fix that interface!!Originally Posted by MaxBlack
at least put the burn speed selection near the BURN button!! or something... not buried in the menus!
Yikes.
need help back here
By natty in forum Newbie / General discussionsReplies: 2Last Post: 18th Mar 2011, 14:52 -
Trying to back up...
By biged670 in forum Newbie / General discussionsReplies: 2Last Post: 1st Jul 2009, 08:54 -
Take a look back.
By gooberguy in forum Off topicReplies: 7Last Post: 21st Jul 2008, 12:22 -
DVDs on hard drive for back up and play back on TV
By yadoc in forum Video ConversionReplies: 2Last Post: 2nd May 2008, 20:03
