I use Womble MPEG Video Wizard for editing the video (AVI files) then encoding with TMPGEnc 2.5 because projects made with Womble MPEG Video Wizard can be directly open in TMPGEnc encoder,(no frameserver is need), but I have problem when I want to change speed in some video clip to slower speed for example.After encoding with TMPGEnc (field order is bean alredy readen when I load the video file made with Womble project) but when I play encoded MPEG 2 file on DVD player the picture motion is not smooth enough.
I don't know how to explain but picture quality is not so good. At the other hand, picture quality is exellent 720x576/8000Kbs when it is encoding without changing the speed of the video. Any sugestions???
Regards.
QUALITY HAS A NAME
Slow motion requires the addition of extra frames. These frames need to be created based on existing frames. The quality of the motion produced is entirely dependent on how well the software can fill the gaps. Some software uses a blending method, some extended cross-fade (similar to blending), and really sophisticated software uses a mixture of warping and morphing along specific motion paths. I would suggest that this is something that womble isn't very good at, and a different method will have to be used if you want better results.
Software that can do good to excellent quality speed changes include Vegas, After Effects with the Twixtor plugin amongst others.Read my blog here.
Super slow motion video experimentation
By snafubaby in forum Video ConversionReplies: 3Last Post: 27th Mar 2012, 11:45 -
Using AutoGK to convert from VOB->AVI results in slow-motion video
By WebMaximus in forum Newbie / General discussionsReplies: 5Last Post: 10th Feb 2012, 14:49 -
MP4Cam2AVI converts my video to slow motion
By sozuki in forum Video ConversionReplies: 2Last Post: 5th Jan 2012, 18:31 -
When i render to dvd in vegas, the output video plays in slow motion, why?
By shadowofanubis6 in forum Newbie / General discussionsReplies: 0Last Post: 1st Mar 2010, 18:41 -
convert DVD segment to slow-motion video
By jackieO in forum Video ConversionReplies: 2Last Post: 7th Oct 2007, 16:36
